Zum Hauptinhalt wechseln
Lenovo ThinkPad T480s Keyboard Replacement
Was du brauchst
  1. Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Lenovo ThinkPad T480s Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Disable the battery, power down, and unplug your device before you begin.
    • Pry the left and right trackpad buttons up with a spudger.
  2. Lenovo ThinkPad T480s Keyboard Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 2, Bild 2 von 2
    • With a Phillips #0 screwdriver, loosen the two captive screws underneath the left and right trackpad buttons.
  3. Lenovo ThinkPad T480s Keyboard Replacement: Schritt 3, Bild 1 von 3 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 3, Bild 2 von 3 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 3, Bild 3 von 3
    • Wedge the spudger under the front edge of the keyboard to push the keyboard toward the back of the system.
    • Lift the front edge of the keyboard up by a few millimeters.
  4. Lenovo ThinkPad T480s Keyboard Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Gently, pull the keyboard out from the bezel and flip it over.
    • It is connected to to the keyboard and trackpad cables so be sure not to yank it over to avoid tearing them.
  5. Lenovo ThinkPad T480s Keyboard Replacement: Schritt 5, Bild 1 von 3 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 5, Bild 2 von 3 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Use the spudger to disconnect the trackpad cable from the system.
    • For more information on types of connectors, check out this guide.
  6. Lenovo ThinkPad T480s Keyboard Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 6, Bild 3 von 3
    • Use the spudger to disconnect the keyboard cable from the system.
  7. Lenovo ThinkPad T480s Keyboard Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad T480s Keyboard Replacement: Schritt 7, Bild 2 von 2
    • Lift the keyboard off of the palm rest.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sarah Westberg
23.372 Reputation
70 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 14
Letzte 7 Tage: 65
Letzte 30 Tage: 257
Insgesamt: 5,957
