Is it possible to change a capacitor?
pirmil -
Mein Problem
Panne complète du MacBookPro. Complete failure, the Mac will not boot!
Meine Reparatur
Démontage relativement facile. Excepté le connecteur des ventilateurs.
Relatively easy disassembly. Except fan connectors
Mein Rat
Une question. Est-il difficile de remplacer le composant [68 C3N] qui a brulé ?
A question. Is it difficult to replace the component [68 C3N] who burned?
1 Kommentar
Totally possible. Take a look on the tutos by Louis Rossmann: https://www.youtube.com/channel/UCl2mFZo...
His videos are so long sometimes but you learn a lot.
Be careful!! If you are not experienced on soldering don't attempt to change this tiny devices. You better practice a bit before doing so.
Alex - Antwort Teilen
