Einleitung
The new iPad Pro 11” sports narrower bezels, curvy LCD corners, and cutting edge silicon. This is apparently the iPad Apple dreamed about building from the very beginning, but what we dream about is a device that is easy to repair. Will this iPad fulfill both dreams, or will ours be left in the pipe? There’s only one way to tell—with a teardown!
Catch our Tweets, or drift through our Facebook and Instagram pages to keep up with the latest Teardown news!
Was du brauchst
Let's take a look at what sets this Pro iPad apart from its amateur peers:
Fully laminated, 11", LED-backlit, Oxide TFT Liquid Retina display with 2388 × 1668 resolution (264 ppi), featuring ProMotion Technology
Octa-core Apple A12X Bionic custom processor, with M12 motion coprocessor and integrated 7-core GPU
12 MP rear camera with 4K video recording at 60 fps, and 7 MP TrueDepth camera with 1080p video
Self-balancing, four-speaker audio
Face ID, five microphones, ambient light sensor, accelerometer, barometer, and 3-axis gyro
802.11a/b/g/n/ac dual band MIMO Wi-Fi + Bluetooth 5.0
64 GB, 256 GB, 512 GB, or 1 TB of on-board storage
With each passing year, Apple seemingly gets closer to realizing its dream of selling a blank slab of glass with its logo on the back.
It's a good thing we've got X-rays on tap from Creative Electron, or this would just look like a black rectangle.
As always, the darkest areas in the X-ray image represent dense materials that absorb more X-rays—usually magnets, such as those used in speakers and for clip-on accessories.
We're seeing considerably more of those than usual here.
Visual inspection time. Above the newly repositioned Smart Connector, we have a new model number: A1980.
Compared with its 10.5" predecessor, it looks about the same, and the lost .2 mm are hard to spot due to the squared-off edges.
Not that we mind at all—it actually reminds us of some of the iPad's more repairable competitors.
Final notes before we dive in: no headphone jack ☹, USB-C port (non-Thunderbolt) in place of Lightning, and a long dark oval to charge the new Pencil.
In diesem Schritt verwendetes Werkzeug:iOpener$24.95
We loved the experience of cutting through all the glue to open our first iPad, and it has never gotten old.
It helps to be practiced at this, but these extra-thin bezels make it even a bit more harrowing than usual. Heat, carve, hold your breath, and hope nothing breaks.
On the plus side, the display's ribbon cables are a safe distance from the bezels—but they're also spread out in a way that makes display removal really awkward.
In diesem Schritt verwendetes Werkzeug:Phillips #00 Screwdriver$5.49
Those cables aren't safe quite yet, as we're forced to lay the display at a weird angle and hopefully not damage anything while we disconnect them.
We put our Phillips driver to work releasing both cable connectors.
Now we see what those X-rays were trying to show us! One thing that immediately stands out is the iPad's quartet of speakers.
Here's the new Liquid Retina display—scaled up from when we first saw it, and packing the same awesome 120 Hz refresh rate we saw on the last iPad Pro.
The fancy new display brings some chips along with it too:
Parade Technologies DP825 timing controller (the same one we saw on the iPad Pro 10.5”)
Texas Instruments TPS65158 (maybe a variation of the TPS65168 LCD Bias IC)
Renesas (formerly Intersil) ISL24833A 18-Ch. TFT-LCD reference voltage generator w/ integrated EEPROM (likely)
Anxious for our first glimpse of that A12X
boxchip, we peel away the logic board cover next. -
Yuck—as always, the board is secured with adhesive, and it's made even fussier by the speakers, which block almost all prying access.
But we're impatient, and soon victorious. The logic board triumphantly emerges from the canyon betwixt the battery cells.
After all that, we're rewarded with some silicon:
Apple APL1083 A12X Bionic SoC
Toshiba TSB3247M61710TWNA1 flash storage (64 GB total)
2x Micron MT53D256M64D4KA-046 XT:B SDRAM (4 GB total)
NXP 100VB27 (SN100V) NFC controller
Apple / USI 339S00551 Wi-Fi / Bluetooth module
2x Broadcom BCM15900B0KWFBG touch screen controller
Texas Instruments CD3215C00 USB-C power controller
These chips can't be contained to just one step, so here are some more:
STMicroelectronics STB601A0 power management (likely)
Apple 343S00252-A0 power management (likely)
Apple 343S00257-A0 power management (likely)
Apple 343S00248-A0 power management (likely)
Texas Instruments 343S00235 charger IC (likely)
Diodes Incorporated PI3DPX1203 DisplayPort 1.3 4-lane linear re-driver
NXP Semiconductor CBTL610 DisplayPort multiplexer (likely)
Main PCB IC Identification, Continued:
Winbond W25Q80DV 8 Mb Serial NOR Flash
ON Semiconductor FUSB301A USB Type-C Controller (Likely)
Analog Devices ADAU7002 Stereo Audio Converter
Maxim Integrated MAX98357A 3.2 W Mono Class D Audio Amplifier
Texas Instruments TPD6S300A USB Type-C Port Protector
Texas Instruments TPS61230A 6 A Step-Up Converter
Texas Instruments TPS61178 10 A Synchronous Boost Converter
Sensor IC Identifications:
Bosch Sensortec Accelerometer/Gyroscope
Bosch Sensortec BMP28x Pressure Sensor (likely)
Battery time! We were not fans of last year's iPads, which skipped out on the stretch-release battery tabs.
This year, pull tabs are back in style—six U-shaped strips this time! Each strip has two tabs, giving fixers a second chance should one of them break. Neat!
But the smooth stops there. A huge patch of supergoop runs all the way down the left side. Sigh. Time to break out the pry tools.
We were left speechless. Why would Apple do this? We could only hypothesize that the adhesive is there for "rigidity reinforcement".
This iPad's powered by a 7812 mAh battery running at 3.77 V, for 29.45 Wh—a slight downgrade from the 30.8 Wh pack in the 10.5" iPad Pro, and a lot smaller than the most recent Microsoft Surface Pro's 45 Wh battery.
Next up, making its debut in the iPad: Face ID.
More specifically, this is the same basic hardware we've seen since iPhone X—IR dot projector, selfie camera, and IR camera—but in a slightly modified form factor.
While we're at it, we fish out the rear camera—which Apple says brings the same performance as the camera from the previous iPads, while being re-engineered for more thinness.
With the loss of OIS, and still a huge camera bump, this design seems shot through with compromise.
Let's remove those speakers, shall we?
That's easier said than tear-done. The housings are carved right into the aluminum case, and were clearly never meant to be removed. Digging them out takes a ton of heat and willpower.
The tweeters come out without a fight but the woofer drivers are pretty much toast—hope they're made of never-fail-ium!
Hiding within the speaker chamber; more magnets! If we had a nickel for every magnet in here, we could melt them all down and make a giant novelty nickel.
Next to come out is the Pencil charging board, with its copper charging coils attached.
While it's technically out, it's not without casualty...
Tiny capacitors and other board bits go flying in protest as we remove the shields. Are we sorry? No we're not.
What's this we see, hiding in the corner? It's an STMicroelectronics STM32L476JGY6 ARM Cortex MCU.
Texas Instruments TPS60151 5V charge pump
ON Semiconductor FPF1204UCX Load Switch
Last to come out is the USB-C port—which unlike previous iPads, is fully modular.
This is a high-wear component, so the ability to replace it independently of the main board is a nice repair win.
It might not be a win for people who are heavily invested in Lightning, but our message to those people is: At least USB-C offers faster throughput in a standardized, non-proprietary form factor.
About the only things left in the chassis are a whole ton of
nickelsmagnets.
Bonus round: we also picked up the new Apple Pencil.
We can already tell, based on the number of visible entry points (read: zero), that this isn't going to be pretty. (Again.)
Let's start with an X-ray before things get messy.
Okay so technically there is one entry point, but we all know nothing's getting in through that tip.
With the tip removed, we go straight for the big guns. Bring out the ultrasonic blade!
When the dust settles, a metal rod emerges from the Apple-white plastic shell.
Looking around, we spot the new wireless charging getup, some magnets, a black sheath, and a wounded teardown engineer. ☹
A large black ribbon cable unfurls from around the Pencil body, revealing what looks like a capacitative grid!
Unfortunately, it's back to destruction from here—the Pencil's many welded steel layers put up quite a fight, and we're only able to reveal a few components.
Battery (even we don't want to tempt that little explosive)
Wireless charging coil
Alignment magnets
Broadcom BCM59358A0 wireless charging IC (likely)
Analog Devices 343S00250 Apple Pencil nib sensor controller (likely)
Apple Pencil IC Identification, Continued:
Bosch Sensortec BMA456 3-axis accelerometer
Maxim Integrated MAX44284 current-sense amplifier
Maxim Integrated MAX4971 overvoltage protection controller
ON Semiconductor NCP161AFCS180T2G 450 mA LDO regulator
SiTime MEMS oscillator
This iPad Pro is no mo'—we've broken it down to its constituent parts!
It's hard to tell if this is a good Apple, or a bad one. There's a modular USB-C port and stretch-release battery adhesive, but it's still mostly glued together and a strip of tough conventional adhesive also secures the battery.
It looks like Apple is trying to change, but the voice on the other shoulder was a little louder than the repairability angel this time around. That said, with all of Apple's late 2018 products showing some improvement, we're hoping the repairability angel is gaining influence.
Fazit
- The USB-C port is modular and can be independently replaced.
- The lack of a physical home button eliminates a common failure point and may simplify repairs.
- The battery is secured with both easier-to-remove stretch-release tabs and conventional, non-removable adhesive.
- The LCD and front panel glass are fused together—simplifying the opening procedure, but increasing the cost of repair.
- Gobs of adhesive hold most everything in place, making all repairs more difficult.
45 Kommentare zur Anleitung
With the 1TB model having 6GB, is that achieved with a higher capacity part or is there space for a third RAM chip?
As I noticed the ram is installed on chip, it is unlikely there will be enough space for a third one
So either the 1TB version uses two 3GB RAM chips (not sure this size exists), or the A12X on the 1TB version offers up the additional 2GB internally, or the flash controller contains 2GB RAM that somehow gets mapped into the OS (doubt this). I have the 1TB version and am just curious how this is implemented.
