Zum Hauptinhalt wechseln
Huawei P8 Lite (2017) Fingerprint Sensor Replacement
Was du brauchst
  1. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Apply a heated iOpener: Schritt 1, Bild 1 von 1
    • Heat an iOpener and apply it to the rear glass for two minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the P8 Lite—the display and internal battery are both susceptible to heat damage.
  2. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Create a gap: Schritt 2, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Create a gap: Schritt 2, Bild 2 von 2
    • Apply a suction cup to the rear glass, as close to the right edge as possible.
    • If the phone's rear glass is cracked, the suction handle may not stick. Try lifting it with strong tape, or superglue the suction handle in place and allow it to cure so you can proceed.
    • Pull up on the suction up with strong, steady force to create a gap.
    • Depending on the age of your device, this may be difficult. If you have trouble, apply more heat to further soften the adhesive and try again.
    • Insert the tip of an opening pick into the gap between the rear glass and frame.
  3. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Slice the adhesive: Schritt 3, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Slice the adhesive: Schritt 3, Bild 2 von 2
    • Slide the tip of the opening pick to the bottom right corner to cut the adhesive.
    • Leave it there to prevent the adhesive from resealing.
  4. Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 4, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 4, Bild 2 von 2
    • Insert a second opening pick at the bottom right corner.
    • Slide the tip of the opening pick to the top right corner to slice the adhesive.
    • Leave the opening pick at its place to prevent the adhesive from resealing.
  5. Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 5, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 5, Bild 2 von 2
    • Insert a third opening pick at the top right corner.
    • Slide it to the top left corner to cut the adhesive.
    • In case you're having trouble to cut the adhesive, reapply the iOpener for another minute to loosen it.
  6. Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 6, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 6, Bild 2 von 2
    • Insert a fourth opening pick at the top left corner.
    • Do not insert the opening pick deeper than 1 cm (1/3rd of an inch) to avoid damage the fingerprint sensor cable.
    • Slide the tip of the opening pick to the bottom left corner to cut the adhesive.
    • Leave the opening pick in its place to prevent the adhesive from resealing.
  7. Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 7, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 7, Bild 2 von 2
    • Insert a fifth opening pick at the bottom left corner.
    • Slide it to the bottom right corner to cut the remaining adhesive.
    • Try not to remove the rear glass yet! The fingerprint sensor is still connected to the motherboard.
  8. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Rotate the rear glass: Schritt 8, Bild 1 von 3 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Rotate the rear glass: Schritt 8, Bild 2 von 3 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Rotate the rear glass: Schritt 8, Bild 3 von 3
    • Open the P8 Lite by swinging the rear glass up from the left side, like the back cover of a book.
    • Place the rear glass on the top of the battery.
    • Avoid tensioning the display cable during this procedure.
  9. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Unscrew the fingerprint sensor connector cover: Schritt 9, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove the 2.9 mm screw.
  10. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Remove the metal shield: Schritt 10, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Remove the metal shield: Schritt 10, Bild 2 von 2
    • Use the tip of an opening pick to pry up and loosen the metal shield.
  11. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Remove the metal shield: Schritt 11, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use a pair of tweezers to remove the metal shield.
  12. Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 12, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 12, Bild 2 von 2
    • Use a spudger to pry up and disconnect the fingerprint sensor cable.
  13. Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 13, Bild 1 von 1
    • Remove the rear glass.
    • After installing the rear glass, apply strong, steady pressure to your phone for several minutes to help the adhesive form a good bond—a stack of heavy books works well.
  14. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Peel off the yellow sticker: Schritt 14, Bild 1 von 3 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Peel off the yellow sticker: Schritt 14, Bild 2 von 3 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Peel off the yellow sticker: Schritt 14, Bild 3 von 3
    Kaufen
    • Use a pair of tweezers to peel off the yellow protective sticker from the fingerprint sensor connector.
  15. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Peel off the black sticker: Schritt 15, Bild 1 von 2 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Peel off the black sticker: Schritt 15, Bild 2 von 2
    • Peel off the black sticker until the sensor is completely exposed.
  16. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Heat an iOpener: Schritt 16, Bild 1 von 1
    • Heat an iOpener and apply it to the rear glass where the fingerprint sensor is located to loosen the adhesive underneath.
  17. Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Slice the adhesive: Schritt 17, Bild 1 von 3 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Slice the adhesive: Schritt 17, Bild 2 von 3 Huawei P8 Lite (2017) Fingerprint Sensor Replacement, Slice the adhesive: Schritt 17, Bild 3 von 3
    • Slide an opening pick underneath the top edge of the small board next to the fingerprint sensor.
    • Use the opening pick to carefully loosen the adhesive underneath the fingerprint board.
    • Slide the opening pick underneath the fingerprint sensor to cut the remaining adhesive holding it in place.
  18. Huawei P8 Lite (2017) Fingerprint Sensor Replacement: Schritt 18, Bild 1 von 1
    • Remove the fingerprint sensor.
Abschluss
Secure the new rear glass with pre-cut adhesive or double-sided adhesive tape.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
Compare your new rear glass to the original part. You may need to transfer the fingerprint sensor or remove adhesive backings from the new part before installing.
Adriana Zwink
48.633 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.299 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 590
