Zum Hauptinhalt wechseln
ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement
Was du brauchst
  1. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Unfasten the lower case: Schritt 1, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Unfasten the lower case: Schritt 1, Bild 2 von 2
    • Remove the 11 Phillips screws securing the lower case:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • Two 6.1 mm screws
    Frag FixBot
    Kommentar hinzufügen
  2. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Insert an opening pick: Schritt 2, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Insert an opening pick: Schritt 2, Bild 2 von 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
    Frag FixBot
  3. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Release the right edge clips: Schritt 3, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Release the right edge clips: Schritt 3, Bild 2 von 2
    • Slide the pick along the right edge to release the clips securing the lower case.
    Frag FixBot
  4. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Release the remaining clips: Schritt 4, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Release the remaining clips: Schritt 4, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Release the remaining clips: Schritt 4, Bild 3 von 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
    Frag FixBot
  5. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement: Schritt 5, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement: Schritt 5, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement: Schritt 5, Bild 3 von 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
    Frag FixBot
  6. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Reposition the plastic: Schritt 6, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Reposition the plastic: Schritt 6, Bild 2 von 2
    • Use your fingers to move the plastic that covers the battery connector out of the way.
    • If the plastic is not staying out of the way use a piece of tape to secure it.
    Frag FixBot
  7. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Disconnect the battery: Schritt 7, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Disconnect the battery: Schritt 7, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Disconnect the battery: Schritt 7, Bild 3 von 3
    • Use the flat end of a spudger to push each side of the battery connector until it comes out of the socket.
    Frag FixBot
  8. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Unfasten the battery: Schritt 8, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Unfasten the battery: Schritt 8, Bild 2 von 2
    • Use a Phillips screwdriver to remove the two 6.1 mm-long screws securing the battery.
    Frag FixBot
  9. ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Remove the battery: Schritt 9, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Remove the battery: Schritt 9, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Battery Replacement, Remove the battery: Schritt 9, Bild 3 von 3
    • Lift the battery straight out of its recess and remove it.
    Frag FixBot
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
6 weitere Personen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
244.730 Reputation
1.203 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
27.624 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 39
Insgesamt: 2,559
