Einleitung
This guide will show you how to replace the battery for your Alienware 17 R3. Be sure you have all the required tools before you begin.
For your safety, discharge your battery below 25% before disassembling your device. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Turn the computer off.
Disconnect the charging cable from the computer.
Unscrew and remove the four 3mm Phillips #1 screws holding the hard drive in place.
Unscrew and remove the four 2mm Phillips #1 screws holding the casing together.
Unscrew the one Phillips #1 screw holding down the bottom of the M.2 chip.
Pull the M.2 chip straight out of its socket.
Unscrew and remove the eight 3mm Phillips #1 screws (located in areas labeled "P").
Remove the six 4mm Phillips #1 screws on the side and the two 10mm Phillips #1 screws on the top.
Flip over the laptop and open it.
Insert the spudger along the edges of the laptop and gently pry upward to lift the keyboard panel.
21 weitere Personen haben diese Anleitung absolviert.
6 Kommentare zur Anleitung
Hi ! Nice DIY . Is it possible to disassemble the battery pack and change the cell inside ?
Hi, please edit step 10. There a 4th ribbon has to be pulled.
Nevertheless a very good manual.
Hi Steffen,
Thanks for the tip! I edited step 10 to correct the mistake.
Very helpful and concise. Worked very well for me. Many Thanks
After putting everything back together I found my didn't HDD work. It was simply that the other end of the HDD cable had become disconnected.
I'd recommend disconnecting this before removing the HDD housing so it doesn't snag (it's actually shown as disconnected in step 10).
