Zum Hauptinhalt wechseln
Backbone One Left Trigger Replacement
Was du brauchst
  1. Backbone One Left Trigger Replacement, Unfasten the screws: Schritt 1, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 5.9 mm-long screws.
    Frag FixBot
    Kommentar hinzufügen
  2. Backbone One Left Trigger Replacement, Rotate the upper cover: Schritt 2, Bild 1 von 3 Backbone One Left Trigger Replacement, Rotate the upper cover: Schritt 2, Bild 2 von 3 Backbone One Left Trigger Replacement, Rotate the upper cover: Schritt 2, Bild 3 von 3
    • Lift up the upper part of the controller.
    • Swing over the upper cover and place it on the controller case.
    • Take care that the interconnecting cable has no tension.
    Frag FixBot
  3. Backbone One Left Trigger Replacement, Remove the protective tape: Schritt 3, Bild 1 von 3 Backbone One Left Trigger Replacement, Remove the protective tape: Schritt 3, Bild 2 von 3 Backbone One Left Trigger Replacement, Remove the protective tape: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of tweezers to remove the yellow protective tape which is placed over the interconnect cable connector.
    Frag FixBot
  4. Backbone One Left Trigger Replacement, Open the ZIF connector: Schritt 4, Bild 1 von 2 Backbone One Left Trigger Replacement, Open the ZIF connector: Schritt 4, Bild 2 von 2
    • Use the tip of an opening pick to open the gray flap of the ZIF connector by pushing it upwards.
    Frag FixBot
  5. Backbone One Left Trigger Replacement, Disconnect the interconnect cable: Schritt 5, Bild 1 von 2 Backbone One Left Trigger Replacement, Disconnect the interconnect cable: Schritt 5, Bild 2 von 2
    • Use your fingers to disconnect the interconnect cable from its connector.
    Frag FixBot
  6. Backbone One Left Trigger Replacement: Schritt 6, Bild 1 von 2 Backbone One Left Trigger Replacement: Schritt 6, Bild 2 von 2
    • Remove the upper half of the left controller assembly.
    Frag FixBot
  7. Backbone One Left Trigger Replacement, Remove the screw: Schritt 7, Bild 1 von 2 Backbone One Left Trigger Replacement, Remove the screw: Schritt 7, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 5.9 mm-long screw which is securing the trigger.
    • The screw is difficult to reach. Insert the screwdriver at an angle of 45 degrees.
    Frag FixBot
  8. Backbone One Left Trigger Replacement, Remove the trigger: Schritt 8, Bild 1 von 2 Backbone One Left Trigger Replacement, Remove the trigger: Schritt 8, Bild 2 von 2
    • Remove the left trigger.
    Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
2 weitere Personen haben diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
123 Mitglieder
31.535 Anleitungen geschrieben
1 Kommentar zur Anleitung
Where can I buy the trigger
Zach - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 18
Letzte 30 Tage: 78
Insgesamt: 4,114
