Zum Hauptinhalt wechseln
Dell Inspiron 3501 Battery Replacement
Was du brauchst
  1. Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: Schritt 1, Bild 1 von 2 Dell Inspiron 3501 Battery Replacement, Unfasten the back cover: Schritt 1, Bild 2 von 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips screwdriver to remove the seven screws securing the back cover:
    • Three 5 mm-long screws
    • Four 7.5 mm-long screws
    • Loosen the three captive screws.
  2. Dell Inspiron 3501 Battery Replacement, Unclip the front corners: Schritt 2, Bild 1 von 2 Dell Inspiron 3501 Battery Replacement, Unclip the front corners: Schritt 2, Bild 2 von 2
    • Flip the laptop upright and open the lid so that the keyboard is exposed.
    • Insert an opening pick between the front right corner of the back cover and the chassis.
    • Pry upward to release the retaining clips holding the cover.
    • You'll hear clicks whenever a clip is released.
    • Repeat this procedure for the opposite corner.
  3. Dell Inspiron 3501 Battery Replacement, Unclip the front edge: Schritt 3, Bild 1 von 2 Dell Inspiron 3501 Battery Replacement, Unclip the front edge: Schritt 3, Bild 2 von 2
    • Insert an opening pick between the front edge of the back cover and the chassis, near the trackpad.
    • Pry upward to release the clips along the front edge of the laptop.
  4. Dell Inspiron 3501 Battery Replacement, Remove the back cover: Schritt 4, Bild 1 von 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: Schritt 4, Bild 2 von 3 Dell Inspiron 3501 Battery Replacement, Remove the back cover: Schritt 4, Bild 3 von 3
    • Close the screen to the laptop and flip it over.
    • Pull the left side of the back cover away from the frame and remove it.
    • If your back cover is stuck to the chassis, use an opening pick to release the clips around the back cover's perimeter.
  5. Dell Inspiron 3501 Battery Replacement, Disconnect the battery: Schritt 5, Bild 1 von 2 Dell Inspiron 3501 Battery Replacement, Disconnect the battery: Schritt 5, Bild 2 von 2
    • Pull the tab on the head of the battery cable away from the socket to disconnect the battery.
  6. Dell Inspiron 3501 Battery Replacement, Unfasten the battery: Schritt 6, Bild 1 von 2 Dell Inspiron 3501 Battery Replacement, Unfasten the battery: Schritt 6, Bild 2 von 2
    • Use a Phillips screwdriver to remove the three 3.3 mm-long screws securing the battery.
  7. Dell Inspiron 3501 Battery Replacement, Remove the battery: Schritt 7, Bild 1 von 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: Schritt 7, Bild 2 von 3 Dell Inspiron 3501 Battery Replacement, Remove the battery: Schritt 7, Bild 3 von 3
    • Lift the battery straight out of its recess and remove it.
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
2 weitere Personen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
162.224 Reputation
769 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.445 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 22
Letzte 30 Tage: 78
Insgesamt: 2,103
