Zum Hauptinhalt wechseln
Dell XPS 15 9520 Battery Replacement
Was du brauchst
  1. Dell XPS 15 9520 Battery Replacement, Unfasten the back cover: Schritt 1, Bild 1 von 2 Dell XPS 15 9520 Battery Replacement, Unfasten the back cover: Schritt 1, Bild 2 von 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Torx T5 screwdriver to remove the eight 3.3 mm-long screws securing the back cover.
  2. Dell XPS 15 9520 Battery Replacement, Insert an opening pick: Schritt 2, Bild 1 von 2 Dell XPS 15 9520 Battery Replacement, Insert an opening pick: Schritt 2, Bild 2 von 2
    • Insert an opening pick between the bottom-left corner of the aluminum back cover and the chassis.
    • Leave the pick inserted before continuing to the next step.
  3. Dell XPS 15 9520 Battery Replacement, Release the corner clip: Schritt 3, Bild 1 von 2 Dell XPS 15 9520 Battery Replacement, Release the corner clip: Schritt 3, Bild 2 von 2
    • Insert the flat end of the spudger into the gap you just created.
    • Pry up to release the corner clips.
    • Repeat this process for the opposite corner of the back cover.
  4. Dell XPS 15 9520 Battery Replacement, Unclip the front edge: Schritt 4, Bild 1 von 3 Dell XPS 15 9520 Battery Replacement, Unclip the front edge: Schritt 4, Bild 2 von 3 Dell XPS 15 9520 Battery Replacement, Unclip the front edge: Schritt 4, Bild 3 von 3
    • Reinsert your opening pick under the aluminum cover at the front edge of the laptop.
    • Pry to loosen the cover.
    • Pry at multiple locations along the front edge to release all of the retaining clips.
    • Do not use a sliding motion along the front edge. This may damage cables near the trackpad.
  5. Dell XPS 15 9520 Battery Replacement, Remove the back cover: Schritt 5, Bild 1 von 3 Dell XPS 15 9520 Battery Replacement, Remove the back cover: Schritt 5, Bild 2 von 3 Dell XPS 15 9520 Battery Replacement, Remove the back cover: Schritt 5, Bild 3 von 3
    • The edges of the back cover are very sharp. Use caution when handling it.
    • Lift the back cover off the chassis and remove it.
    • If the back cover feels stuck to the chassis, use an opening pick to release any remaining clips around the back cover's perimeter.
  6. Dell XPS 15 9520 Battery Replacement, Disconnect the battery: Schritt 6, Bild 1 von 3 Dell XPS 15 9520 Battery Replacement, Disconnect the battery: Schritt 6, Bild 2 von 3 Dell XPS 15 9520 Battery Replacement, Disconnect the battery: Schritt 6, Bild 3 von 3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  7. Dell XPS 15 9520 Battery Replacement, Remove the tape: Schritt 7, Bild 1 von 3 Dell XPS 15 9520 Battery Replacement, Remove the tape: Schritt 7, Bild 2 von 3 Dell XPS 15 9520 Battery Replacement, Remove the tape: Schritt 7, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers, or your fingers, to peel back the tape connecting the speaker cable and the battery.
    • Repeat for the three other tape segments.
  8. Dell XPS 15 9520 Battery Replacement, Unfasten the battery: Schritt 8, Bild 1 von 2 Dell XPS 15 9520 Battery Replacement, Unfasten the battery: Schritt 8, Bild 2 von 2
    • Use a Phillips screwdriver to remove the eight screws securing the battery:
    • Four 4.4 mm-long screws
    • Four 3.4 mm-long screws
  9. Dell XPS 15 9520 Battery Replacement, Remove the battery: Schritt 9, Bild 1 von 3 Dell XPS 15 9520 Battery Replacement, Remove the battery: Schritt 9, Bild 2 von 3 Dell XPS 15 9520 Battery Replacement, Remove the battery: Schritt 9, Bild 3 von 3
    • Lift the battery straight out of its recess and remove it.
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
4 weitere Personen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
234.438 Reputation
1.139 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
124 Mitglieder
25.208 Anleitungen geschrieben
4 Kommentare zur Anleitung
Thanks Alex, easy to follow
John Carmichael - Antwort Teilen
I need to remove the cable from the battery because my new battery did not have one. Do you know how to get this connector to let go? I didn't want to force it.
Petrus Prinsloo - Antwort Teilen
The cable for the battery seems to pull straight up from the battery to disconnect it, after which it can be attached to the new battery by just pressing it onto the battery.
johann beda - Antwort Teilen
I did not notice the absence of the connector on the new battery until after [I screwed all 8 battery screws in, scrolled up to reverse the battery removal instructions, realize I was not able to find the connector, and unscrewed all 8 battery screws again]. After that, I realized the old battery had a connector that I could use with the new battery.
This guide is less than ½ of a battery replacement guide; knowing how to remove the battery is quite helpful, but the guide, as is, is not foolproof.
Please, please improve this guide.
I plan [[to check the comments section of future part-replacement guides that I follow] and [to think much more carefully, fool that I am, before doing any actual replacement] whenever I notice the guide skipped everything after removal].
Mark Andrew Gerads - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 17
Letzte 7 Tage: 113
Letzte 30 Tage: 468
Insgesamt: 8,055
