Einleitung
Use this guide to replace a cracked or broken touch screen assembly on your Fitbit Charge 2.
If the watch frame is deformed, we strongly suggest replacing it to make sure the new touch screen will mount correctly and won’t suffer damage from uneven pressure.
Was du brauchst
Before starting, take your Fitbit Charge 2 off the charger and power it down.
Remove the watch band on both sides.
Heat an iOpener and apply it to the touch screen for two minutes.
In diesem Schritt verwendetes Werkzeug:iSesamo Opening Tool$9.99
Insert an iSesamo into the gap between the touch screen and the watch assembly on the top left corner.
Slide the iSesamo along the left edge to the bottom left corner.
Slide the iSesamo around the bottom left corner.
Slide it along the edge to the bottom right corner.
Slide the iSesamo around the bottom right corner.
Keep sliding it along the right edge to the top right corner.
Slide the iSesamo around the top right corner.
Slide it along the top edge to the top left corner.
Place the iSesamo under the top left corner.
Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap and unhinge the plastic clips which are holding the screen in place.
Place the iSesamo under the top right corner.
Pry up the touch screen assembly by twisting the iSesamo sideways to create a gap.
Insert a spudger into the gap on the top edge of your Fitbit Charge 2.
Use the spudger to pry up the touch screen assembly.
Use the pointed end of a spudger to open the ZIF connector by pushing up the black flap.
Pull the touch screen flex cable straight out its socket.
Remove the touch screen assembly.
If possible, turn on your device and test your repair before reassemble.
Opening didn’t go as planned? Ask our Answers community for help.
11 weitere Nutzer:innen haben diese Anleitung absolviert.
