Zum Hauptinhalt wechseln
Google Pixel 2 XL Charging Assembly Replacement
Was du brauchst
  1. Google Pixel 2 XL Charging Assembly Replacement, SIM Card: Schritt 1, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement, SIM Card: Schritt 1, Bild 2 von 2
    • Insert a SIM card eject tool or a paperclip into the small hole in the SIM card tray, located on the left edge of the phone, opposite of the power and volume buttons.
    • Press firmly to eject the tray.
  2. Google Pixel 2 XL Charging Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the SIM card tray from the phone.
    • The SIM card will fall out of the tray easily.
    • When reinserting the SIM card, ensure that it is in the proper orientation relative to the tray.
  3. Google Pixel 2 XL Charging Assembly Replacement, Opening Procedure: Schritt 3, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement, Opening Procedure: Schritt 3, Bild 2 von 2
    • If your display glass is cracked, tape over the glass to prevent bodily harm and further breakage. This also makes a smooth surface allowing the suction cup to bond.
    • Apply a suction cup as close to the SIM slot edge of the phone as you can while avoiding the curved edge.
    • The suction cup will not make a good seal on the curved portion of the glass.
  4. Google Pixel 2 XL Charging Assembly Replacement: Schritt 4, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 4, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 4, Bild 3 von 3
    • Pull up on the suction cup with firm, constant pressure and insert an opening pick between the front panel and rear case.
    • This requires a significant amount of force and patience. If you have trouble, rock the suction cup and screen to weaken the adhesive, or apply heat with an iOpener, heat gun, or hair dryer.
  5. Google Pixel 2 XL Charging Assembly Replacement: Schritt 5, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 5, Bild 2 von 2
    • In the following steps, extra caution is required in certain areas to avoid damage to the phone:
    • Do not insert the pick more than 0.25 inches (6 mm) into the bottom edge of the phone. If the pick contacts the folded portion of the OLED panel, it can damage the display.
    • Do not cut along the left edge; there are delicate display cables that can be damaged.
    • Only make very shallow cuts in the upper left corner; prying deeply can damage the front-facing camera.
  6. Google Pixel 2 XL Charging Assembly Replacement: Schritt 6, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 6, Bild 2 von 2
    • Slide the opening pick down the right side of the phone to separate the display adhesive.
  7. Google Pixel 2 XL Charging Assembly Replacement: Schritt 7, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 7, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 7, Bild 3 von 3
    • In the following steps, use the flat edge of the opening pick, rather than a corner, to cut. This will help prevent inserting the pick too deeply.
    • Slide the opening pick around the lower-right corner and along the bottom edge of the phone.
  8. Google Pixel 2 XL Charging Assembly Replacement: Schritt 8, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 8, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 8, Bild 3 von 3
    • Reinsert the flat edge of the pick at the top-right corner of the phone, and slide it around the corner and the top edge of the phone.
  9. Google Pixel 2 XL Charging Assembly Replacement: Schritt 9, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 9, Bild 2 von 2
    • Gently lift the display from the right side of the phone, opening it like a book.
    • If the display doesn't readily lift, do some extra prying to separate the last of the adhesive.
    • Don't try to fully separate the display yet, as fragile ribbon cables still connect it to the phone's motherboard.
    • Carefully lay the display flat on the table next to the rest of the phone, keeping it close to the phone to avoid straining the display and digitizer cables.
  10. Google Pixel 2 XL Charging Assembly Replacement: Schritt 10, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 10, Bild 2 von 2
    • Use the corner of an opening tool to pry up and unclip on the lower edge of the digitizer cable connector cover.
    • The clip securing this cover is along the bottom edge.
    • Pry carefully to avoid damaging the cable underneath, or losing the cover itself.
    • Remove the connector cover.
    • Make sure to keep this component so you can reinstall it during reassembly.
  11. Google Pixel 2 XL Charging Assembly Replacement: Schritt 11, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 11, Bild 2 von 2
    • Use the point of a spudger to lift the digitizer cable connector up and out of its socket on the motherboard.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
    • If any part of your screen doesn't respond to touch after your repair, re-seat this connector, making sure it clicks fully into place and that there's no dust or other obstruction in the socket.
  12. Google Pixel 2 XL Charging Assembly Replacement: Schritt 12, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to remove any tape from the display connector cover.
  13. Google Pixel 2 XL Charging Assembly Replacement: Schritt 13, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 13, Bild 2 von 2
    • Insert the point of a spudger into the small hole on the edge of the display connector cover.
    • Use the spudger to pry the cover out of its recess.
  14. Google Pixel 2 XL Charging Assembly Replacement: Schritt 14, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 14, Bild 2 von 2
  15. Google Pixel 2 XL Charging Assembly Replacement, Midframe: Schritt 15, Bild 1 von 1
    Magnetic Project Mat
    $19.95
    • Remove eleven 3.8 mm Phillips screws securing the midframe.
  16. Google Pixel 2 XL Charging Assembly Replacement: Schritt 16, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 16, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 16, Bild 3 von 3
    • Insert an opening tool into the notch in the midframe near the volume buttons and pry the midframe up and away from the rest of the phone.
    • Remove the midframe.
  17. Google Pixel 2 XL Charging Assembly Replacement, Battery Connector: Schritt 17, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement, Battery Connector: Schritt 17, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the battery connector.
  18. Google Pixel 2 XL Charging Assembly Replacement, Motherboard: Schritt 18, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement, Motherboard: Schritt 18, Bild 2 von 2
    • Use the point of a spudger to disconnect the front-facing camera connector.
    • During reassembly, it's easiest to attach the front camera to the motherboard, then insert the motherboard.
  19. Google Pixel 2 XL Charging Assembly Replacement: Schritt 19, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 19, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 19, Bild 3 von 3
    • Use the flat end of a spudger to disconnect the right Active Edge sensor connector.
    • Disconnect the antenna cable.
  20. Google Pixel 2 XL Charging Assembly Replacement: Schritt 20, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 20, Bild 2 von 2
    • Use the point of a spudger to disconnect the fingerprint sensor connector.
  21. Google Pixel 2 XL Charging Assembly Replacement: Schritt 21, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 21, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the left Active Edge sensor connector.
  22. Google Pixel 2 XL Charging Assembly Replacement: Schritt 22, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 22, Bild 2 von 2
    • Use the flat end of a spudger to disconnect the charging assembly connector.
  23. Google Pixel 2 XL Charging Assembly Replacement: Schritt 23, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 23, Bild 2 von 2
    • Use the point of a spudger to disconnect the front-facing sensor assembly connector.
  24. Google Pixel 2 XL Charging Assembly Replacement: Schritt 24, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 24, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 24, Bild 3 von 3
    • Make sure all the cables and connectors are clear of the board, and use the flat edge of a spudger to gently lift the bottom of the motherboard.
    • The narrow part of the motherboard is very fragile. If it starts to bend when you lift, stop and make sure there isn't anything holding the board down. The board should lift up without any resistance.
    • Holding the wide part of the motherboard near the SIM card slot, carefully slide the board toward the bottom of the phone while lifting it out of the phone.
    • Remove the motherboard.
    • Try to keep the phone flat with the battery facing up after you remove the motherboard, as the front-facing camera can fall out of the phone case very easily.
    • When reinstalling the motherboard, move all the cables and connectors out of the way of the board and make sure all connectors are aligned with their respective sockets.
  25. Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: Schritt 25, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: Schritt 25, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement, Loudspeaker: Schritt 25, Bild 3 von 3
    • Slide the point of a spudger under the lower left side of the loudspeaker and slowly pry the speaker assembly up from the phone.
    • If you're having trouble, try inserting the flat end of a spudger into the gap at the base of the phone and slowly pry up.
  26. Google Pixel 2 XL Charging Assembly Replacement: Schritt 26, Bild 1 von 1
    • Remove the loudspeaker from the phone.
  27. Google Pixel 2 XL Charging Assembly Replacement, Charging Assembly: Schritt 27, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement, Charging Assembly: Schritt 27, Bild 2 von 2
    • Use the point of a spudger to disconnect the white antenna cable to the right of the battery.
  28. Google Pixel 2 XL Charging Assembly Replacement: Schritt 28, Bild 1 von 1
    • Use a hairdryer or heat gun, or prepare an iOpener and apply it to the bottom of the back of the phone for about a minute, in order to soften the adhesive securing the charging assembly.
  29. Google Pixel 2 XL Charging Assembly Replacement: Schritt 29, Bild 1 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 29, Bild 2 von 3 Google Pixel 2 XL Charging Assembly Replacement: Schritt 29, Bild 3 von 3
    • Starting from the left side, slide an opening pick under the charging assembly flex cable to separate it from the phone case.
  30. Google Pixel 2 XL Charging Assembly Replacement: Schritt 30, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 30, Bild 2 von 2
    • Gently pull the USB-C port out of its recess in the phone case.
    • The antenna board is still adhered to the phone case. Do not remove the charging assembly or strain the flex cable connecting the antenna board and the USB-C port.
  31. Google Pixel 2 XL Charging Assembly Replacement: Schritt 31, Bild 1 von 2 Google Pixel 2 XL Charging Assembly Replacement: Schritt 31, Bild 2 von 2
    • Slowly slide the point of a spudger underneath the antenna board to separate the adhesive tape under the board.
    • Pry slowly and carefully to avoid putting too much strain on the board.
  32. Google Pixel 2 XL Charging Assembly Replacement: Schritt 32, Bild 1 von 1
    • Lift the charging assembly out of the phone case.
Abschluss
33 weitere Personen haben diese Anleitung absolviert.
Adam O'Camb
222.657 Reputation
416 Anleitungen geschrieben
12 Kommentare zur Anleitung
Take your time removing the screen. I was bit impatient and cracked it :( . The screen is the most expensive part of the phone now so will be very costly for me to replace
Shan - Antwort Teilen
Why do I need the Tesa 61395 Tape for this repair? I don’t see it used anywhere in the guide.
Jay Huxley - Antwort Teilen
Hey Jay,
The Tesa tape is needed only necessary if you do not use the custom-cut back display panel adhesive.
Arthur Shi - Antwort Teilen
Should I apply some kind of glue around the port?
Is there any possibility to keep it waterproof?
Erik Cej - Antwort Teilen
Hi Erik,
Once you have opened the phone, there is no reliable DIY way to make it water resistant.
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 26
Letzte 30 Tage: 101
Insgesamt: 25,823
