Zum Hauptinhalt wechseln
How to Open Your Logitech MX Anywhere 3 for Mac
Was du brauchst
  1. How to Open Your Logitech MX Anywhere 3 for Mac, Soften the mouse feet adhesive: Schritt 1, Bild 1 von 2 How to Open Your Logitech MX Anywhere 3 for Mac, Soften the mouse feet adhesive: Schritt 1, Bild 2 von 2
    • Flip the mouse's power switch into the OFF position, unplug any cables, and flip it over so the feet are facing up.
    • The unique shape of some mice can prevent them from laying flat. If you need to, lay your mouse on a soft towel to prevent wobble.
    • If you're planning to reuse your existing mouse feet, note that the adhesive needs to be thoroughly heated for them to be cleanly removed.
    • Heat an iOpener and apply it to the mouse feet for about two minutes.
    • Alternatively, you can use a hair dryer to soften the mouse feet adhesive.
    • When using a hair dryer, don't heat the feet for more than a couple seconds at a time—anything hotter than just warm to the touch risks melting or warping the plastic lower case.
  2. How to Open Your Logitech MX Anywhere 3 for Mac, Disassembly information: Schritt 2, Bild 1 von 2 How to Open Your Logitech MX Anywhere 3 for Mac, Disassembly information: Schritt 2, Bild 2 von 2
    • There are small gaps in the rims surrounding each foot. This is where to place the tool in the next step.
  3. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: Schritt 3, Bild 1 von 3 How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: Schritt 3, Bild 2 von 3 How to Open Your Logitech MX Anywhere 3 for Mac, Remove the feet: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Push the tip of an opening pick underneath the mouse foot adhesive, into the gap in the rim.
    • Go slowly, and make sure the pick slides underneath both the foot and its adhesive pad. These layers separate easily.
    • If you plan on reusing your mouse feet, be careful not to crease them or separate them from their adhesive pads.
    • Slide your pick under the foot to separate its adhesive until you can grab it with your fingers.
    • Repeat to remove the three remaining mouse feet.
    • For installing new mouse feet or reusing your old ones:
    • Use a pair of tweezers or a spudger to remove any large chunks of leftover adhesive. Thoroughly clean the bottom of the mouse with isopropyl alcohol and a lint-free of microfiber cloth. Allow the surface to dry completely.
    • Peel your new mouse feet away from their adhesive liners and press them firmly into place.
  4. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the case screws: Schritt 4, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 4.3 mm-long screws securing the two halves of the mouse together.
  5. How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: Schritt 5, Bild 1 von 3 How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: Schritt 5, Bild 2 von 3 How to Open Your Logitech MX Anywhere 3 for Mac, Open the mouse: Schritt 5, Bild 3 von 3
    • Gently open the top half of the mouse up and flip it over to the right, like a book.
    • Don't try to fully remove the top shell just yet—a cable connects the upper shell to the lower case.
  6. How to Open Your Logitech MX Anywhere 3 for Mac, Disconnect the interconnect cable: Schritt 6, Bild 1 von 2 How to Open Your Logitech MX Anywhere 3 for Mac, Disconnect the interconnect cable: Schritt 6, Bild 2 von 2
    • Use the tip of a spudger, an opening tool, or your fingernail to flip up the small, hinged locking flap on the interconnect cable's ZIF connector.
  7. How to Open Your Logitech MX Anywhere 3 for Mac: Schritt 7, Bild 1 von 2 How to Open Your Logitech MX Anywhere 3 for Mac: Schritt 7, Bild 2 von 2
    • Pull the cable straight out of its socket.
    • During reassembly, insert the cable with its blue tab facing up, then flip down the locking flap.
  8. How to Open Your Logitech MX Anywhere 3 for Mac, Remove the top half of the mouse: Schritt 8, Bild 1 von 1
    • Remove the top half of the mouse.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Clay Eickemeyer
68.062 Reputation
453 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.525 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 31
Insgesamt: 328
