Zum Hauptinhalt wechseln
How to Open and Clean an Xbox Series X (Digital Edition)
Was du brauchst
  1. How to Open and Clean an Xbox Series X (Digital Edition), Uncover the back panel screws: Schritt 1, Bild 1 von 2 How to Open and Clean an Xbox Series X (Digital Edition), Uncover the back panel screws: Schritt 1, Bild 2 von 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Two stickers cover the back panel screws. You can remove the stickers without heating them, though it makes them much easier to remove cleanly.
    • Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
    • Alternatively, you can use a hair dryer to heat the sticker.
  2. How to Open and Clean an Xbox Series X (Digital Edition): Schritt 2, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 2, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 2, Bild 3 von 3
    • Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  3. How to Open and Clean an Xbox Series X (Digital Edition): Schritt 3, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 3, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 3, Bild 3 von 3
    • Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
  4. How to Open and Clean an Xbox Series X (Digital Edition): Schritt 4, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 4, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 4, Bild 3 von 3
    • Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
    • Use blunt tweezers to peel back the sticker to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  5. How to Open and Clean an Xbox Series X (Digital Edition), Remove the back panel screws: Schritt 5, Bild 1 von 2 How to Open and Clean an Xbox Series X (Digital Edition), Remove the back panel screws: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Magnetic Project Mat
    $19.95
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
  6. How to Open and Clean an Xbox Series X (Digital Edition), Unclip the back panel: Schritt 6, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Unclip the back panel: Schritt 6, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Unclip the back panel: Schritt 6, Bild 3 von 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  7. How to Open and Clean an Xbox Series X (Digital Edition): Schritt 7, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 7, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 7, Bild 3 von 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  8. How to Open and Clean an Xbox Series X (Digital Edition), Remove the back panel: Schritt 8, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Remove the back panel: Schritt 8, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Remove the back panel: Schritt 8, Bild 3 von 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  9. How to Open and Clean an Xbox Series X (Digital Edition): Schritt 9, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 9, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition): Schritt 9, Bild 3 von 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  10. How to Open and Clean an Xbox Series X (Digital Edition), Remove the fan screws: Schritt 10, Bild 1 von 2 How to Open and Clean an Xbox Series X (Digital Edition), Remove the fan screws: Schritt 10, Bild 2 von 2
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.3 mm‑long pancake screw
    • Two 9 mm‑long screws
  11. How to Open and Clean an Xbox Series X (Digital Edition), Disconnect the fan cable: Schritt 11, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Disconnect the fan cable: Schritt 11, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Disconnect the fan cable: Schritt 11, Bild 3 von 3
    • Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
    • Grip your tweezers close the connector to get a better grip.
    • Pull the connector straight out of the socket to disconnect it.
    • If you're having trouble, gently rock the connector side to side to loosen it.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  12. How to Open and Clean an Xbox Series X (Digital Edition), Remove the fan: Schritt 12, Bild 1 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Remove the fan: Schritt 12, Bild 2 von 3 How to Open and Clean an Xbox Series X (Digital Edition), Remove the fan: Schritt 12, Bild 3 von 3
    • Slide the fan out of its slot to remove it.
    • During reassembly, note that the fan can only be installed one way—make sure Master Chief is facing you.
  13. How to Open and Clean an Xbox Series X (Digital Edition), Clean the fan: Schritt 13, Bild 1 von 2 How to Open and Clean an Xbox Series X (Digital Edition), Clean the fan: Schritt 13, Bild 2 von 2
    Dust Blower
    $18.99
    • Over time, dust will build up inside the fan and on the fan blades.
    • Use a pair of tweezers to grab loose hairs and dust clumps off of the fan.
    • Use a small dust blower or light compressed air to blow remaining dust off of the fan.
    • Use a finger to keep the fan blades steady—it makes them easier to clean.
    • If there's a layer of grime on the fan blades, use soapy water on a damp rag or an isopropyl alcohol wipe to clean it off.
  14. How to Open and Clean an Xbox Series X (Digital Edition), Clean the exterior panels and vent holes: Schritt 14, Bild 1 von 2 How to Open and Clean an Xbox Series X (Digital Edition), Clean the exterior panels and vent holes: Schritt 14, Bild 2 von 2
    Microfiber Cleaning Cloths
    $3.99
    • Use a clean rag or microfiber cloth to wipe both sides of the back panel clean.
  15. How to Open and Clean an Xbox Series X (Digital Edition), Clean the heatsink: Schritt 15, Bild 1 von 1
    • The Xbox Series X draws air up through the large heatsink fins, and they may clog with dust and debris over time.
    • Use a dust blower to blow out any trapped dust from both sides of the heatsink fins.
    • If you need to remove the heatsink for deeper cleaning, follow this guide up to the chassis removal step.
  16. How to Open and Clean an Xbox Series X (Digital Edition), Clean hard-to-reach areas: Schritt 16, Bild 1 von 1
    Anti-Static Brush
    $2.99
    • Depending on how dirty the inside of your console is, you might need to use a soft bristle brush to dislodge more dust and grime.
    • Using an anti-static brush or a new toothbrush, clean any dust out of hard to reach areas.
    • Once most dust is dislodged, use a dust blower to blow it out of the console.
    • Remember: use this time to clean any other dirty internal surfaces before you seal your console back up. Happy gaming!
Abschluss
Disassembly didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
Spencer Day
95.960 Reputation
662 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.648 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 68
Insgesamt: 376
