Xbox Series X (Digital Edition) Accessory Antenna Board Replacement
Einleitung
Zu Schritt 1 der AnleitungUse this guide to replace the accessory antenna board in your Xbox Series X (Digital Edition) gaming console.
Before you begin, completely power down and unplug all cables from your console. Remember to follow general electrostatic discharge (ESD) safety procedures while repairing your console.
Was du brauchst
Ersatzteile
Werkzeuge
Mehr anzeigen …
Heat an iOpener and lay it on the smaller sticker near the bottom of the back panel for two minutes.
Use a pair of angled tweezers to remove the sticker hiding the first screw on the back panel, near the base.
Use an iOpener or hair dryer to heat the larger sticker near the center of the back panel.
Use the flat end of a spudger to scrape up a corner of the larger sticker until you can grip it with a pair of blunt tweezers.
Use blunt tweezers to peel back the sticker to reveal the second screw.
In diesem Schritt verwendetes Werkzeug:Magnetic Project Mat$19.95
Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
Pry up the back panel to release it from the locking clips.
Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
Remove the back panel.
Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
One 10.3 mm‑long pancake screw
Two 9 mm‑long screws
Use your fingernails or a pair of angled tweezers to firmly grip the edges of the fan cable connector.
Pull the connector straight out of the socket to disconnect it.
In diesem Schritt verwendetes Werkzeug:Dust Blower$18.99
Slide the fan out of its slot to remove it.
Before installing the fan, make sure it's clean! Use a dust blower or compressed air to blow off any dust or debris, and wipe the fan clean with a clean cloth.
Note that the fan can only be installed one way—make sure Master Chief is facing you.
Use the flat end of a spudger to pry up the locking tab holding the base to the shell.
Keep the locking tab held open for the next step.
With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
Remove the base.
Use a spudger to flip open the metal locking tab on the USB port ribbon cable.
Use an iOpener or a hair dryer to heat the USB port cable.
In diesem Schritt verwendetes Werkzeug:Tesa 61395 Tape$2.99
Slide an opening pick under the USB port cable to separate the adhesive securing it.
Use a pair of tweezers to gently pull up on the black plastic pull tab to disconnect the USB port cable.
Move the USB port cable out of the way of the chassis.
Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
Use a T8 Torx driver to remove the three 7.4 mm‑long green screws securing the center chassis assembly to the shell.
In diesem Schritt verwendetes Werkzeug:Dust Blower$4.99
Gently place the chassis heatsink-side down on a clean work surface.
Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
