Zum Hauptinhalt wechseln
How to Open the Huawei Watch GT 2 (42 mm)
Was du brauchst
  1. How to Open the Huawei Watch GT 2 (42 mm), Remove the watch band: Schritt 1, Bild 1 von 1
    • Before starting the repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Huawei Watch GT 2 (42 mm), Unfasten the screws: Schritt 2, Bild 1 von 1
    • Use a T2 Torx screwdriver to remove the four 3.6 mm screws securing the back cover assembly.
  3. How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: Schritt 3, Bild 1 von 3 How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: Schritt 3, Bild 2 von 3 How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: Schritt 3, Bild 3 von 3
    • Insert an opening tool in the seam on the top edge between the back cover assembly and the watch case.
    • Use the opening tool to pry up the back cover assembly of your Huawei Watch GT 2 (42 mm).
    • Don't fully remove the back cover assembly just yet. It's still connected to the motherboard.
  4. How to Open the Huawei Watch GT 2 (42 mm), Lift the back cover assembly: Schritt 4, Bild 1 von 2 How to Open the Huawei Watch GT 2 (42 mm), Lift the back cover assembly: Schritt 4, Bild 2 von 2
    • Carefully swing the back cover assembly open to an upward position.
Abschluss
To reassemble your Huawei Watch GT 2 (42 mm), follow these instructions in reverse order.
Opening didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
Adriana Zwink
48.633 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.299 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 13
Letzte 30 Tage: 86
Insgesamt: 3,062
