Zum Hauptinhalt wechseln
How to Replace the Thermal Paste in your Mac mini (2024)
Was du brauchst
  1. How to Replace the Thermal Paste in your Mac mini (2024), Before you begin: Schritt 1, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Before you begin: Schritt 1, Bild 2 von 2
    • Fully shut down your Mac mini and unplug all cables from it.
    • Flip over your Mac mini and place it on a clean, flat surface to avoid scratching the chassis.
  2. How to Replace the Thermal Paste in your Mac mini (2024), Create a gap: Schritt 2, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Create a gap: Schritt 2, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Create a gap: Schritt 2, Bild 3 von 3
    • Insert a Jimmy into the gap between the bottom cover and the chassis.
    • Pry up the bottom cover to create a gap.
    • Keep the Jimmy inserted under the bottom cover.
  3. How to Replace the Thermal Paste in your Mac mini (2024), Insert an opening pick: Schritt 3, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Insert an opening pick: Schritt 3, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Insert an opening pick: Schritt 3, Bild 3 von 3
    • Insert an opening pick into the gap created by the Jimmy.
    • Remove the Jimmy.
  4. How to Replace the Thermal Paste in your Mac mini (2024), Release the clips: Schritt 4, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Release the clips: Schritt 4, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Release the clips: Schritt 4, Bild 3 von 3
    • Slide the opening pick along the bottom cover until you feel it snag on a clip.
    • There are four clips total—one at each corner of the bottom cover.
    • Twist the pick to lift the clip out of its slot.
  5. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 5, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 5, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 5, Bild 3 von 3
    • Continue sliding and prying with the pick along the perimeter of the bottom cover to release the remaining clips.
    • Don't insert the pick more than an inch when sliding near the power button, as you risk damaging the cable.
    • During reassembly, press along the perimeter of the bottom until you hear and feel all four clips click back into place.
  6. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 6, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 6, Bild 2 von 2
    • Don't remove the bottom cover yet, as it's still connected to the Mac mini with a cable.
    • Lift the edge of the bottom cover opposite the power button and flip it over to expose the power button cable.
  7. How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the power button: Schritt 7, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the power button: Schritt 7, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the power button: Schritt 7, Bild 3 von 3
    • Grip the power button cable close to the head and pull it away from its socket to disconnect it.
  8. How to Replace the Thermal Paste in your Mac mini (2024), Remove the bottom cover: Schritt 8, Bild 1 von 1
    • Remove the bottom cover.
  9. How to Replace the Thermal Paste in your Mac mini (2024), Remove the inner plate screws: Schritt 9, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the inner plate screws: Schritt 9, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    FixMat
    $36.95
    • While the Mac mini uses Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to prevent stripping.
    • Use a T5 Torx screwdriver to remove the twelve screws securing the inner plate:
    • Eight 3.4 mm‑long screws
    • Four 2.4 mm‑long screws
  10. How to Replace the Thermal Paste in your Mac mini (2024), Separate the inner plate: Schritt 10, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Separate the inner plate: Schritt 10, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Separate the inner plate: Schritt 10, Bild 3 von 3
    • Insert the point of a spudger into one of the clips' slots on the inner plate.
    • Pry up the inner plate enough so you can grip the edge along the same side as the headphone jack.
  11. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 11, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 11, Bild 2 von 2
    • Pull the inner plate away from the chassis to slide it out from under the lip on the heat sink.
    • During reassembly, slide the inner plate back under the heat sink and press along its edges to secure it in the chassis.
  12. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 12, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 12, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 12, Bild 3 von 3
    • Don't remove the inner plate yet, as it's still connected to the Mac mini by a cable.
    • Lift the inner plate and flip it over to expose the wireless module cable.
  13. How to Replace the Thermal Paste in your Mac mini (2024), Remove the wireless module cover: Schritt 13, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the wireless module cover: Schritt 13, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the wireless module cover: Schritt 13, Bild 3 von 3
    • Use one hand to secure the wireless module during this step.
    • Use a Torx Plus 5IP screwdriver to remove the four 2.5 mm‑long screws securing the wireless module cover.
  14. How to Replace the Thermal Paste in your Mac mini (2024), Remove the cover: Schritt 14, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the cover: Schritt 14, Bild 2 von 2
    • Remove the wireless module cover.
    • During reassembly, look the bottom of the cover to find the foam rectangle. Align the foam rectangle over the wireless module press connector to find the proper orientation for the cover.
  15. How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the wireless module: Schritt 15, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the wireless module: Schritt 15, Bild 2 von 2
    • Insert the point of a spudger under one of the short edges of the wireless module press connector.
    • Don't insert your spudger anywhere else, as you risk dislodging surface-mounted components.
    • Pry up to disconnect the wireless module.
  16. How to Replace the Thermal Paste in your Mac mini (2024), Remove the inner plate: Schritt 16, Bild 1 von 1
    • Remove the inner plate.
  17. How to Replace the Thermal Paste in your Mac mini (2024), Remove the fan screws: Schritt 17, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the fan screws: Schritt 17, Bild 2 von 2
    • If you're following this guide to clean your fan, this is a good time to do so.
    • Remove the four screws securing the fan:
    • Two 2.4 mm‑long Torx Plus 3IP screws
    • Two 7.9 mm‑long Torx Plus 5IP screws
  18. How to Replace the Thermal Paste in your Mac mini (2024), Reposition the fan: Schritt 18, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Reposition the fan: Schritt 18, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Reposition the fan: Schritt 18, Bild 3 von 3
    • Lift the fan out of its recess in the chassis and flip it over to expose its wire and connector.
    • Let the fan rest on the chassis and heat sink.
  19. How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the fan: Schritt 19, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the fan: Schritt 19, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the fan: Schritt 19, Bild 3 von 3
    • Use tweezers to peel back the tape covering the fan ZIF connector.
  20. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 20, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 20, Bild 2 von 2
    • Use the point of a spudger, or your fingernail, to flip up the locking tab on the fan ZIF connector.
  21. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 21, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 21, Bild 2 von 2
    • Use tweezers, or your fingers, to slide the ZIF connector straight out of its socket.
  22. How to Replace the Thermal Paste in your Mac mini (2024), Remove the fan: Schritt 22, Bild 1 von 1
    • Remove the fan.
  23. How to Replace the Thermal Paste in your Mac mini (2024), Remove the headphone jack cover screws: Schritt 23, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the headphone jack cover screws: Schritt 23, Bild 2 von 2
    • Use a Torx Plus 3IP screwdriver to remove the two 2.2 mm‑long screws securing the headphone jack cover.
  24. How to Replace the Thermal Paste in your Mac mini (2024), Remove the cover: Schritt 24, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the cover: Schritt 24, Bild 2 von 2
    • Use tweezers, or your fingers, to remove the headphone jack cover.
  25. How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the headphone jack: Schritt 25, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the headphone jack: Schritt 25, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the headphone jack press connector.
  26. How to Replace the Thermal Paste in your Mac mini (2024), Remove the headphone jack screws: Schritt 26, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the headphone jack screws: Schritt 26, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the headphone jack screws: Schritt 26, Bild 3 von 3
    • Use a Torx Plus 3IP screwdriver to remove the two 4.0 mm‑long screws securing the headphone jack.
    • If you aren't using a flexible adapter, make sure your screwdriver is as parallel with the screw as possible. Apply constant force against the screw to avoid stripping.
  27. How to Replace the Thermal Paste in your Mac mini (2024), Apply isopropyl alcohol: Schritt 27, Bild 1 von 1
    • The power indicator light is connected to the headphone jack and requires separating its adhesive to continue.
    • Apply a few drops of isopropyl alcohol (>90%) to the top of the power indicator's silver plate.
    • Wait one minute for the alcohol to flow behind the power indicator and for the adhesive to loosen.
  28. How to Replace the Thermal Paste in your Mac mini (2024), Separate the power indicator: Schritt 28, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Separate the power indicator: Schritt 28, Bild 2 von 2
    Tesa 61395 Tape
    $5.99
    • Slide a Jimmy between the top of the power indicator and the chassis to separate the adhesive.
    • During reassembly, align the power indicator's holes over the white pegs in the chassis. If the old adhesive isn't sticky anymore, use a thin double-sided tape like Tesa Tape to replace it.
  29. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 29, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 29, Bild 2 von 2
    • Lightly grip the power indicator with tweezers and pull it away from the chassis to separate the adhesive securing its cable.
  30. How to Replace the Thermal Paste in your Mac mini (2024), Remove the headphone jack: Schritt 30, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the headphone jack: Schritt 30, Bild 2 von 2
    • Lift the headphone jack out of the chassis and remove it.
  31. How to Replace the Thermal Paste in your Mac mini (2024), Remove the speaker screws: Schritt 31, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the speaker screws: Schritt 31, Bild 2 von 2
    • Use a Torx Plus 5IP screwdriver to remove the three screws securing the speaker:
    • Two 4.1 mm‑long screws
    • One 3.7 mm‑long screw
  32. How to Replace the Thermal Paste in your Mac mini (2024), Reposition the speaker: Schritt 32, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Reposition the speaker: Schritt 32, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Reposition the speaker: Schritt 32, Bild 3 von 3
  33. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 33, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 33, Bild 2 von 2
    • Pull the speaker over the edge of the chassis to expose its cable and its connector.
    • Rest the speaker on the edge of the chassis.
  34. How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the speaker: Schritt 34, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the speaker: Schritt 34, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the speaker: Schritt 34, Bild 3 von 3
    • Grip the speaker cable close to the head and pull it away from its socket to disconnect it.
  35. How to Replace the Thermal Paste in your Mac mini (2024), Remove the speaker: Schritt 35, Bild 1 von 1
    • Remove the speaker.
  36. How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C port cover screws: Schritt 36, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C port cover screws: Schritt 36, Bild 2 von 2
    • Remove the four screws securing the USB-C port cover:
    • Three 2.2 mm‑long Torx Plus 3IP screws
    • One 9.2 mm‑long Torx Plus 8IP screw
  37. How to Replace the Thermal Paste in your Mac mini (2024), Remove the cover: Schritt 37, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the cover: Schritt 37, Bild 2 von 2
    • Use tweezers, or your fingers, to remove the front USB-C port cover.
  38. How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the front USB-C ports: Schritt 38, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the front USB-C ports: Schritt 38, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the front USB-C ports press connector.
  39. How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C port screws: Schritt 39, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C port screws: Schritt 39, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C port screws: Schritt 39, Bild 3 von 3
    • Use a Torx Plus 3IP screwdriver to remove the four 4.7 mm‑long screws securing the two front USB-C ports.
  40. How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C ports: Schritt 40, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C ports: Schritt 40, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the front USB-C ports: Schritt 40, Bild 3 von 3
    • Use the point of a spudger to pry the front USB-C ports from their recesses in the chassis.
    • During reassembly, gently press the USB-C ports into their recesses until they click into place.
  41. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 41, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 41, Bild 2 von 2
    • Pull the front USB-C ports out of the chassis and remove it.
  42. How to Replace the Thermal Paste in your Mac mini (2024), Remove the logic board screws: Schritt 42, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the logic board screws: Schritt 42, Bild 2 von 2
    • Remove the six screws securing the logic board:
    • Three 6.8 mm‑long T8 Torx screws
    • One 16.2 mm‑long T8 Torx screw
    • Two 4.2 mm‑long T5 Torx screws
  43. How to Replace the Thermal Paste in your Mac mini (2024), Release the logic board: Schritt 43, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Release the logic board: Schritt 43, Bild 2 von 2
    • Grip the heat sink and pull it away from the edge of the chassis to release the pegs in the rear ports.
  44. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 44, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 44, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 44, Bild 3 von 3
    • Don't fully remove the logic board from the chassis yet, as it's still attached by a cable.
    • Lift the rear port side of the logic board out of the chassis before sliding the opposite end out.
    • During reassembly, insert the edge of the logic board opposite the rear ports into the chassis before pressing it down flat.
  45. How to Replace the Thermal Paste in your Mac mini (2024): Schritt 45, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 45, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024): Schritt 45, Bild 3 von 3
    • Turn the logic board over to expose the power supply cable connector.
  46. How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the power supply: Schritt 46, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Disconnect the power supply: Schritt 46, Bild 2 von 2
    • Use your fingers to grip the power supply cable connector and pull it straight out of its socket to disconnect it.
  47. How to Replace the Thermal Paste in your Mac mini (2024), Remove the logic board: Schritt 47, Bild 1 von 1
    • Remove the logic board.
  48. How to Replace the Thermal Paste in your Mac mini (2024), Remove the logic board cover: Schritt 48, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the logic board cover: Schritt 48, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the logic board cover: Schritt 48, Bild 3 von 3
    • The rubber cover on the bottom of the logic board is secured with adhesive along its copper pads.
    • Flip over the logic board.
    • While securing the logic board with one hand, use the other to peel off the rubber cover.
    • If pieces of the copper rip and stick to the logic board, don't worry! Keep the copper in place, as it'll fill in the gaps on the rubber cover during reassembly.
  49. How to Replace the Thermal Paste in your Mac mini (2024), Remove the heat sink bracket screws: Schritt 49, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the heat sink bracket screws: Schritt 49, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the heat sink bracket screws: Schritt 49, Bild 3 von 3
    • Use one hand to secure the logic board during this step to prevent damaging it.
    • Use a Torx Plus 5IP screwdriver to remove the four 4.4 mm‑long screws securing the heat sink bracket.
    • The brackets will bend up as you loosen the screws.
    • During reassembly, tighten the heat sink bracket screws in an "X" pattern.
  50. How to Replace the Thermal Paste in your Mac mini (2024), Remove the brackets: Schritt 50, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the brackets: Schritt 50, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the brackets: Schritt 50, Bild 3 von 3
    • Use tweezers, or your fingers, to remove the heat sink brackets.
  51. How to Replace the Thermal Paste in your Mac mini (2024), Remove the heat sink screws: Schritt 51, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the heat sink screws: Schritt 51, Bild 2 von 2
    • Use a Torx Plus 5IP screwdriver to remove the two 4.0 mm‑long screws securing the heat sink.
  52. How to Replace the Thermal Paste in your Mac mini (2024), Remove the heat sink: Schritt 52, Bild 1 von 2 How to Replace the Thermal Paste in your Mac mini (2024), Remove the heat sink: Schritt 52, Bild 2 von 2
    • Lift the heat sink off the logic board and remove it.
    • You might feel a little resistance from the thermal paste bonded to the heat sink.
  53. How to Replace the Thermal Paste in your Mac mini (2024), Remove the old thermal paste: Schritt 53, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the old thermal paste: Schritt 53, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Remove the old thermal paste: Schritt 53, Bild 3 von 3
    • Use the flat end of a spudger to scrape off the old thermal paste from the processor.
    • Apply a few drops of isopropyl alcohol (>90%) to the processor and use a coffee filter or a lint-free cloth to wipe away any residue.
    • Repeat this step for the thermal paste on the heat sink.
  54. How to Replace the Thermal Paste in your Mac mini (2024), Apply the new thermal paste: Schritt 54, Bild 1 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Apply the new thermal paste: Schritt 54, Bild 2 von 3 How to Replace the Thermal Paste in your Mac mini (2024), Apply the new thermal paste: Schritt 54, Bild 3 von 3
    • Apply a small bead of thermal paste to the each of the three locations on the processor.
    • Follow this guide in reverse order starting with this step to reattach the heat sink. Placing the heat sink back on the processor will evenly spread the thermal paste and bond both parts together.
Abschluss
To reassemble your device, follow these instructions in reverse order, starting with this step.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Mac mini (2024) Answers Community for help.
Alex Diaz-Kokaisl
161.984 Reputation
769 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
118 Mitglieder
19.413 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 76
Letzte 30 Tage: 325
Insgesamt: 1,129
