Zum Hauptinhalt wechseln
How to open the SteelSeries Nimbus+ Controller
Was du brauchst
  1. How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: Schritt 1, Bild 1 von 2 How to open the SteelSeries Nimbus+ Controller, Remove the phone mount: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    Frag FixBot
    Kommentar hinzufügen
  2. How to open the SteelSeries Nimbus+ Controller, Remove the sticker: Schritt 2, Bild 1 von 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    Frag FixBot
  3. How to open the SteelSeries Nimbus+ Controller, Unscrew the back cover: Schritt 3, Bild 1 von 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    Frag FixBot
  4. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: Schritt 4, Bild 1 von 2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: Schritt 4, Bild 2 von 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    Frag FixBot
  5. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: Schritt 5, Bild 1 von 2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: Schritt 5, Bild 2 von 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    Frag FixBot
  6. How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: Schritt 6, Bild 1 von 2 How to open the SteelSeries Nimbus+ Controller, Insert an opening pick: Schritt 6, Bild 2 von 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    Frag FixBot
  7. How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: Schritt 7, Bild 1 von 2 How to open the SteelSeries Nimbus+ Controller, Release the plastic clips: Schritt 7, Bild 2 von 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    Frag FixBot
  8. How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: Schritt 8, Bild 1 von 3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: Schritt 8, Bild 2 von 3 How to open the SteelSeries Nimbus+ Controller, Unfold the back cover assembly: Schritt 8, Bild 3 von 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    Frag FixBot
  9. How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: Schritt 9, Bild 1 von 3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: Schritt 9, Bild 2 von 3 How to open the SteelSeries Nimbus+ Controller, Disconnect the battery cable: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    Frag FixBot
  10. How to open the SteelSeries Nimbus+ Controller, Remove the back cover assembly: Schritt 10, Bild 1 von 1
    • Remove the back cover assembly.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.812 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 49
Insgesamt: 2,094
