Zum Hauptinhalt wechseln
LG Front Load Washing Machine Stator Replacement
Was du brauchst
    1. LG Front Load Washing Machine Stator Replacement, Safety Precautions: Schritt 1, Bild 1 von 2 LG Front Load Washing Machine Stator Replacement, Safety Precautions: Schritt 1, Bild 2 von 2
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      Frag FixBot
      Kommentar hinzufügen
    1. LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: Schritt 2, Bild 1 von 3 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: Schritt 2, Bild 2 von 3 LG Front Load Washing Machine Stator Replacement, Unfasten the rear panel: Schritt 2, Bild 3 von 3
      • Remove the screw(s) securing the rear panel.
      Frag FixBot
    2. LG Front Load Washing Machine Stator Replacement, Remove the rear panel: Schritt 3, Bild 1 von 3 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: Schritt 3, Bild 2 von 3 LG Front Load Washing Machine Stator Replacement, Remove the rear panel: Schritt 3, Bild 3 von 3
      • Unclip the rear panel from the chassis.
      Frag FixBot
    3. LG Front Load Washing Machine Stator Replacement: Schritt 4, Bild 1 von 1
      • Remove the rear panel.
      Frag FixBot
    1. LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: Schritt 5, Bild 1 von 2 LG Front Load Washing Machine Stator Replacement, Unfasten the rotor: Schritt 5, Bild 2 von 2
      • Use an impact driver to remove the 17 mm nut securing the rotor.
      • Alternatively, you can use a wrench and a hammer to loosen the nut.
      • To secure the rotor, you can insert a screwdriver, or a similar tool, between the rotor and the stator. Make sure to brace the tool against one of the screw bosses on the stator.
      Frag FixBot
    2. LG Front Load Washing Machine Stator Replacement, Remove the rotor: Schritt 6, Bild 1 von 2 LG Front Load Washing Machine Stator Replacement, Remove the rotor: Schritt 6, Bild 2 von 2
      • The rotor is magnetically attracted to the stator.
      • Pull the rotor straight off the stator and drive shaft splines to remove it.
      • Wiggle the rotor as you pull to help disconnect it.
      • This may require significant force.
      • During reassembly, watch your fingers when aligning the rotor over the stator, as the rotor gets sucked in easily.
      Frag FixBot
    1. LG Front Load Washing Machine Stator Replacement, Unfasten the motor harness: Schritt 7, Bild 1 von 1
      • Remove the screw(s) securing the motor harness.
      Frag FixBot
    2. LG Front Load Washing Machine Stator Replacement, Unfasten the stator: Schritt 8, Bild 1 von 2 LG Front Load Washing Machine Stator Replacement, Unfasten the stator: Schritt 8, Bild 2 von 2
      • Hold the stator up as you unfasten the last few bolts, as it can fall over unexpectedly.
      • Remove the bolts securing the stator.
      • During reassembly, refasten the screws in a "star" pattern.
      Frag FixBot
    3. LG Front Load Washing Machine Stator Replacement, Reposition the stator: Schritt 9, Bild 1 von 3 LG Front Load Washing Machine Stator Replacement, Reposition the stator: Schritt 9, Bild 2 von 3 LG Front Load Washing Machine Stator Replacement, Reposition the stator: Schritt 9, Bild 3 von 3
      • Don't pull the stator too far away from the device, as it's still connected by wires.
      • Pull the stator out of its slot on the drum, and flip it so its rear is facing upward.
      Frag FixBot
    4. LG Front Load Washing Machine Stator Replacement, Disconnect the stator: Schritt 10, Bild 1 von 3 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: Schritt 10, Bild 2 von 3 LG Front Load Washing Machine Stator Replacement, Disconnect the stator: Schritt 10, Bild 3 von 3
      • Disconnect the connectors attached to the stator.
      • Always grip cables by their connectors and not the wires themselves.
      Frag FixBot
    5. LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: Schritt 11, Bild 1 von 3 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: Schritt 11, Bild 2 von 3 LG Front Load Washing Machine Stator Replacement, Remove the rotor position sensor: Schritt 11, Bild 3 von 3
      • Use your fingers to unclip the rotor position sensor from the stator.
      • Pull the sensor away from the stator to completely unclip it.
      • Remove the rotor position sensor.
      • You're left with the stator.
      Frag FixBot
Abschluss
Repair didn’t go as planned? Ask our Answers community for help.
2 weitere Personen haben diese Anleitung absolviert.
Bill Gilbert
40.159 Reputation
261 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
35.371 Anleitungen geschrieben
5 Kommentare zur Anleitung
I don’t have comment just question. Does this particular model have a drive belt? Mine is not spinning properly
Leilani Seymour - Antwort Teilen
No it does not. It is a direct drive machine, meaning that the motor drives the wash basket directly. Take a look at this link for some help.
Bill Gilbert - Antwort Teilen
I undertook this repair with the wd14071sd6 model to replace the hall sensor as I was getting the LE error code. I have noted on step 2 that the entire back panel had to be removed to access the rotor. This is very very awkward, as multiple electrics are also connected to the panel via plastic clips.
Despite this, the repair can be achieved without any major electric disconnection work just a matter or having enough space to carefully remove things.
Phill Birtles - Antwort Teilen
Te alguns estator que não usam o sensor Hall a minha lava seca LG wd17vts6 está máquina tem sensor Hall no estator
Dúvidas, obrigado
ROMUALDO GUIMARAES - Antwort Teilen
A máquina LG wd17vrs6 (modelo) usa sensor Hall no seu estator
Dúvida poderia me informar
Obrigado
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 23
Letzte 30 Tage: 78
Insgesamt: 2,458
