Einleitung
Use this guide to replace or upgrade the M.2 2280 SSD in your Lenovo Legion Y7000P laptop.
This laptop is compatible with PCIe NVMe Gen 3 and 4 SSDs.
Before you perform this repair, back up your existing SSD if possible. If you're replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Was du brauchst
Unplug all cables and fully shut down your laptop.
Use a Phillips screwdriver to remove the 11 screws securing the back cover:
Five 11.5 mm‑long screws
Six 4.7 mm-long screws
Insert the flat side of an opening pick between the top right corner of the back cover and frame.
Slide the opening pick down the right edge and around the bottom right corner to release the clips.
Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
Slide the two tabs near the center of the back cover's top edge under the hinge cover.
Press down firmly around the perimeter of the back cover to engage all the clips.
A stiff, black cover runs across the heatsink and fans.
Heat an iOpener and apply it to the cover for two minutes.
Use the flat end of a spudger to push the battery connector straight out of its socket.
Use a Phillips screwdriver to remove the 3.9 mm‑long screw securing the SSD.
Check your repair by running hardware tests with Lenovo Diagnostics.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
