Einleitung
Use this guide to replace the display assembly of your Lenovo ThinkPad T480. The display assembly is the screen paired with the frame of the laptop.
If the frame of your Lenovo ThinkPad T480 is damaged or bent and you need to replace the LCD screen , you may need to replace the whole display assembly because the LCD screen may not seat correctly due to the bent frame. Damage like this could occur because of a drop or fall.
Prior to beginning this repair, be sure to disable the internal battery, turn off the laptop, and unplug it from the charging cable.
Was du brauchst
Using your fingers, slide the lock on each side of the battery to the unlocked position.
Remove the battery from the slot.
Use the Phillips #1 screwdriver to loosen the two screws parallel to the battery compartment.
Push the keyboard towards the screen and away from the trackpad and then slide it out towards you gently.
Flip the keyboard over towards you to expose the backside of the keyboard and the two ribbon connectors.
Using the black nylon spudger, flip the first ribbon connector lock open. Slide the first connector out.
Using the black nylon spudger, unlock the second ribbon connector and slide it out from the port.
Insert the blue plastic opening tool into the space between the lower case and the chassis.
Slide the opening tool around the perimeter of the case to release the clips holding the case and the chassis together.
Remove the back case.
Using the Phillips #1 screwdriver, remove the two 4.6 mm screws securing the internal battery to the frame.
Use the spudger to slide the battery socket connector parallel to the motherboard and out of its socket on the motherboard.
Using the black nylon spudger, wedge the battery up from the case and lift it out.
Pull the black plastic sheet back to reveal the RAM stick.
Using your fingers, pull the metal arms (located on both sides of the RAM stick) slightly away from it .
Using the Phillips #1 screwdriver, remove the single 3.6 mm screw at the top of the Wi-Fi card attaching it to the motherboard.
Insert the point of a spudger under one of the antenna cables close to the connector. Pry straight up to disconnect the cable off of the Wi-Fi card.
Using an IC extractor or black nylon spudger, unplug the connector from the socket on the motherboard.
Using the black nylon spudger, pry the coin cell battery off of the motherboard.
Using the Phillips #1 screwdriver, loosen the four captive screws in the arm of the heatsink.
Use the black nylon spudger to slide the fan connector parallel to the motherboard and out of its socket on the motherboard.
Using the black nylon spudger, lift the connector lock up.
Disconnect the storage cable from the system board.
Lift the hard drive up with a tab if it has one or with your spudger.
Lift the drive assembly from the system.
Using the Phillips #1 screwdriver, remove three 4.6 mm screws from the I/O bracket.
Using the Phillips #1 screwdriver, remove the three 4.1 mm screws from the RJ45 bracket.
Lift the bracket off of the motherboard.
Use the black nylon spudger to lift up the small locking flap on the power button cable's ZIF connector.
Slide the power button cable out of the ZIF connector.
Use the tip of a spudger or an opening tool, to flip up the small, hinged locking flap on the camera cable connector to remove the cable from the motherboard.
Using the black nylon spudger, remove the NFC cable connector and trackpad connector from the motherboard.
Using the Phillips #1 screwdriver, remove seven 3.6 mm screws from the motherboard.
Lift the motherboard off of the case to remove it.
Using the Phillips #1 screwdriver, remove two 4.3 mm screws from each hinge (four total).
Lift the keyboard bezel up and slide it out from the hinges to separate it from the LCD assembly.
