Zum Hauptinhalt wechseln
Lenovo ThinkPad T490s Battery Replacement
Was du brauchst
  1. Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: Schritt 1, Bild 1 von 2 Lenovo ThinkPad T490s Battery Replacement, Loosen the back screws: Schritt 1, Bild 2 von 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use your Phillips #1 screwdriver to fully loosen the five screws on the back cover.
    • These screws are captive—they won't come out after being unscrewed.
  2. Lenovo ThinkPad T490s Battery Replacement, Release the clips: Schritt 2, Bild 1 von 2 Lenovo ThinkPad T490s Battery Replacement, Release the clips: Schritt 2, Bild 2 von 2
    • Orient your laptop so that the screen's silver hinges are closest to you.
    • Insert an opening pick between the back cover and the device body near a hinge corner.
    • Pry upward to release the clips holding the cover. Listen for a loud click when each clip releases.
  3. Lenovo ThinkPad T490s Battery Replacement: Schritt 3, Bild 1 von 2 Lenovo ThinkPad T490s Battery Replacement: Schritt 3, Bild 2 von 2
    • Insert your opening pick between the cover and the device body at the other hinge corner.
    • Pry upward to release additional retaining clips.
  4. Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: Schritt 4, Bild 1 von 3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: Schritt 4, Bild 2 von 3 Lenovo ThinkPad T490s Battery Replacement, Remove the back cover: Schritt 4, Bild 3 von 3
    • Grab the front edge of the cover and lift it away from you.
    • There may be additional clips holding the cover in place. These remaining clips will release easily as you remove the cover.
  5. Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: Schritt 5, Bild 1 von 2 Lenovo ThinkPad T490s Battery Replacement, Disconnect the battery cable: Schritt 5, Bild 2 von 2
    • Grab the battery pull-tab at the head of the connector.
    • Pull the connector out of its socket in the direction of the cable.
  6. Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: Schritt 6, Bild 1 von 2 Lenovo ThinkPad T490s Battery Replacement, Unfasten the battery: Schritt 6, Bild 2 von 2
    • Use a Phillips #0 screwdriver to remove the five 5.2 mm-long screws securing the battery.
  7. Lenovo ThinkPad T490s Battery Replacement, Remove the battery: Schritt 7, Bild 1 von 3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: Schritt 7, Bild 2 von 3 Lenovo ThinkPad T490s Battery Replacement, Remove the battery: Schritt 7, Bild 3 von 3
    • Lift the battery straight out of its recess and remove it.
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
Alex Diaz-Kokaisl
125.070 Reputation
582 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
136 Mitglieder
17.430 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 19
Letzte 7 Tage: 86
Letzte 30 Tage: 366
Insgesamt: 5,029
