Zum Hauptinhalt wechseln
Lenovo Yoga 6 13ALC6 Battery Replacement
Was du brauchst
  1. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: Schritt 1, Bild 1 von 2 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the lower case: Schritt 1, Bild 2 von 2
    • Use a T5 Torx screwdriver to remove the six 7.2 mm screws securing the lower case.
  2. Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: Schritt 2, Bild 1 von 2 Lenovo Yoga 6 13ALC6 Battery Replacement, Insert the opening pick: Schritt 2, Bild 2 von 2
    • Insert an opening pick between the lower case and the chassis at a hinge corner.
    • Pry up with the pick to release the clips securing the lower case.
    • Repeat the process on the other hinge corner.
  3. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: Schritt 3, Bild 1 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: Schritt 3, Bild 2 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the clips: Schritt 3, Bild 3 von 3
    • Slide the pick along the right edge to release the clips securing the lower case.
  4. Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: Schritt 4, Bild 1 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: Schritt 4, Bild 2 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Release the remaining clips: Schritt 4, Bild 3 von 3
    • Continue sliding the opening pick along the front and left edges to release the remaining clips.
  5. Lenovo Yoga 6 13ALC6 Battery Replacement: Schritt 5, Bild 1 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement: Schritt 5, Bild 2 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement: Schritt 5, Bild 3 von 3
    • Insert the pick on the hinge edge and slide along the entire edge to release all of the clips.
  6. Lenovo Yoga 6 13ALC6 Battery Replacement: Schritt 6, Bild 1 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement: Schritt 6, Bild 2 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement: Schritt 6, Bild 3 von 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
  7. Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: Schritt 7, Bild 1 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: Schritt 7, Bild 2 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Disconnect the battery: Schritt 7, Bild 3 von 3
    • Use the pointed end of a spudger to push each side of the battery connector until it comes out of the socket.
  8. Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: Schritt 8, Bild 1 von 2 Lenovo Yoga 6 13ALC6 Battery Replacement, Unfasten the battery: Schritt 8, Bild 2 von 2
    • Use a Phillips screwdriver to remove the five 4.2 mm-long screws securing the battery.
  9. Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: Schritt 9, Bild 1 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: Schritt 9, Bild 2 von 3 Lenovo Yoga 6 13ALC6 Battery Replacement, Remove the battery: Schritt 9, Bild 3 von 3
    • Lift the battery straight out of its recess and remove it.
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Alex Diaz-Kokaisl
125.789 Reputation
592 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
137 Mitglieder
17.524 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 29
Letzte 30 Tage: 158
Insgesamt: 2,117
