Einleitung
Use this guide to safely remove and replace the battery in a Logitech Craft wireless keyboard.
Note: If your battery looks puffy or swollen, take extra precautions.
Was du brauchst
Before you begin, flip the keyboard's power switch into the OFF position.
Flip the keyboard over, laying the it key-side down onto a clean work surface.
Heat an iOpener and lay it on the left rear plastic foot for about two minutes.
Insert the pointed end of a spudger at the edge of the foot.
Push the spudger underneath the foot and pry up to release its adhesive.
Once you can grip the foot with your fingers, peel it up and away from the keyboard to remove it.
Use a Phillips screwdriver to remove the 4.7 mm screw securing the bottom cover.
Hold the keyboard upside down.
Grip the bottom cover and slide it towards the ON/OFF switch to unlock it from the rest of the device.
Lay the keyboard back down onto your work surface.
Lightly push down on the bottom cover and slide it towards the ON/OFF switch.
Remove the bottom cover.
Use the pointed end of a spudger to lift up the small locking flap on the interconnect cable's ZIF connector.
Use a pair of tweezers to slide the interconnect cable out of its connector.
Use the pointed end of a spudger to lift up the small locking flap on the opposite end of the interconnect cable.
Remove the interconnect cable.
Use a pair of tweezers to remove the two remaining pieces of foam securing the battery wires.
Use a pair of tweezers to slide the battery wires out from underneath their plastic cable routing clips, on either side of the battery.
Use a pair of blunt tweezers to grip the edges of the left battery cable connector.
Pull the connector away from the left daughterboard to disconnect it.
Use the pair of blunt tweezers to grip the edges of the right battery cable connector.
Pull the connector away from the right daughterboard to disconnect it.
Insert the flat edge of a spudger underneath one short edge of the battery.
Push the spudger underneath the battery, separating it from the adhesive holding it to the keyboard.
Remove the battery.
Remove any leftover adhesive from the battery well.
Apply double sided tape or pre-cut adhesive to secure the new battery.
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
fantastic instructions, where can I get a replacement battery?
