Einleitung
Follow this guide to replace either or both of the lower cameras in front of your Meta Quest 2 headset.
This guide shows how to remove the lower right camera as you're looking at the front of the Meta Quest 2. Removing the lower left camera follows a similar procedure.
Note: You'll need a long PH00 bit or a dedicated PH00 screwdriver to remove some recessed screws.
Was du brauchst
Hold the power button for three seconds to fully turn off your headset.
Grasp and pull on the nose section of the facial interface to unclip it from the headset.
Grasp and pull on the top section of the facial interface to unclip it from the headset.
Use your fingers to grasp the right strap near the headset.
Peel the right strap away from the headset arm to unclip it.
Unthread the top strap from its bracket.
Remove the head strap.
Use a Torx T2 driver to remove the six 3.5 mm‑long screws securing the eyepiece trim.
Insert an opening pick into the seam between the eyepiece trim and white outer shell, near the nose cutout.
Slide the opening pick to the right along the seam to release the clips securing the eyepiece trim.
Pry with the opening pick to release the clips securing the right side of the eyepiece trim.
Leave the opening pick in the seam to prevent the clips from reengaging.
Repeat the prying procedure along the left edge to release the clips securing the eyepiece trim.
Lift the eyepiece trim slightly and tilt it towards the top edge of the headset.
Set the trim down on your work surface, making sure not to strain the cable.
Use the point of a spudger to flip open the black lock tab on the ZIF connector securing the face sensor cable.
Make sure the lens spacing matches the spacing indicator. This allows the indicator peg to sit correctly in its notch.
If the lens spacing doesn't match the indicator, manually adjust the lens with your fingers.
Thread your fingers through the eyepiece trim’s eyeholes and grasp the edges of the sensor cable.
Slide the sensor cable into the socket until the first set of tabs rests in the socket. This should flip the lock tab down partially.
Use a spudger to press the lock tab down towards the cable to lock it in place.
Use a Phillips screwdriver to remove the five 7.7 mm‑long screws securing the front cover to the headset:
One recessed in the top-left corner
One recessed in the top-right corner
Three along the lower edge
Insert an opening pick into the seam between the bottom edge of the front cover and the headset.
Pry with the opening pick to release the front cover clips.
Slide the opening clip along the seam and pry to release all the clips securing the front cover.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a pair of tweezers to grasp the metal neck of the top-right antenna cable.
Lift the antenna connector straight up to disconnect it.
Guide the antenna cable out of its metal clip holding it in place.
Use a Phillips screwdriver to remove the three screws securing the battery cable bracket:
One 4.4 mm‑long screw
Two 2.3 mm‑long screws
Use tweezers or your fingers to grasp the battery cable bracket.
Twist the cable bracket slightly so that its bottom left corner unclips from the motherboard.
Remove the battery cable bracket.
Use a spudger to pry up and disconnect the battery press connector from the motherboard.
Use a Phillips screwdriver to remove the eight screws securing the antenna assembly to the headset:
Four 4.4 mm‑long screws
Two 4.8 mm‑long screws
Two 10.7 mm‑long screws
Use your fingers to flip up the antenna assembly enough to access the cable underneath it.
Use a spudger to pry up and disconnect the lower camera connector.
Slide an opening pick under the camera cable to loosen it from the headset.
Use a Phillips screwdriver to remove the two 3.5 mm‑long screws securing the camera.
