Einleitung
Use this guide to remove or replace the rear cover on your Motorola Moto G7 Power.
Before you begin, download the Rescue and Smart Assistant app to backup your device and diagnose whether your problem is software or hardware related.
Some images may have visual discrepancies, such as the SIM card tray being removed from the phone. You don’t need to remove the SIM card tray for this procedure.
You’ll need some double-sided tape (such as Tesa tape) in order to adhere the replaced components.
For your safety, discharge the battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair. If your battery is swollen, take appropriate precautions.
Was du brauchst
Apply a heated iOpener or a heat gun to the bottom edge of the screen for approximately two minutes to help soften the adhesive.
Apply a suction cup to the rear cover, as close to the heated edge as possible.
Pull up on the suction cup with strong, steady force to create a gap.
Insert an opening pick into the gap you created under the rear cover.
Slide the pick along the bottom of the gap to slice through the adhesive securing the rear cover to the midframe.
Slide the pick along the gap on the same side of the phone as the SIM card tray to slice through the adhesive securing the rear cover to the midframe.
Slide the pick along the gap at the top of the phone to slice through the adhesive securing the rear cover to the midframe.
Slightly lift up the rear cover starting from the right side.
This will prevent damage to the fingerprint sensor connector under the left side of the rear cover.
Use a finger to press down on the fingerprint sensor until it separates from the rear cover.
Remove the rear cover, taking care not to damage the fingerprint sensor.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Motorola Moto G7 Power Answers community for help.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
3 weitere Personen haben diese Anleitung absolviert.
