Einleitung
This guide shows how to remove and replace a worn or drifting left joystick (aka thumbstick) on your PlayStation Portal.
If you're replacing the right joystick, follow this guide instead.
Was du brauchst
Before you begin repairs, power off your PlayStation Portal and unplug any cables.
Rest a finger over the L1 bumper to prevent it from flying off when you pry.
Insert the flat end of a spudger between the top edge of the bumper and the white shell.
Pry up to unclip the bumper.
Slide the spudger along the seam to release any remaining clips.
Align the bumper into its slot.
Use a finger to press the bumper down firmly until it clicks into place.
Insert the tip of an opening pick underneath the left joystick trim strip, where it wraps below the grip.
Twist the opening pick to release the bottom clip.
Insert the tip of an opening pick underneath the outer edge of the trim strip.
Slide the opening pick along the edge to release the clips.
Insert the tip of an opening pick under the inner edge of the strip.
Grasp the bottom edge of the trim strip and slowly lift to release any remaining clips.
Lift and remove the left joystick trim strip.
Repeat the procedure to unclip and remove the right joystick trim strip.
Use your fingers to align and clip the top edge in place.
Firmly press along the remaining edges to clip the strip in place.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws at the bottom tips of each grip.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the top corners of the shell.
Push the flat edge of a spudger into the back shell's left, inner seam.
Keep the spudger inserted in the seam.
Insert the tip of an opening pick into the shell's left, outer seam.
Slide the pick along the seam to release the clips securing the edge.
Keep a pick in the seam to prevent the shell from clipping back together.
Repeat the previous three steps on the right side of the Portal to release the clips along the right edge.
Carefully flip your Portal over.
Grasp the top edge of the back shell, near a corner.
Gently pull the top edge away until you feel the clips release in that corner.
Grasp the bottom edge of the back shell, near the center.
Pull away with firm force to release the clips securing the bottom edge.
Align the corners near the trigger buttons first.
Firmly press around the entire perimeter to clip the shell back in place.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left grip shell to the Portal.
Grasp the top edge of the grip shell and twist it slightly outwards (away from the screen) to release the inner clips.
Insert the flat edge of a spudger underneath the inner edge of the grip shell, near the vibration motor.
Twist the spudger along the edge to unclip the bottom portion of the grip shell.
Remove the left grip shell.
Use a Phillips screwdriver to remove the two 6.5 mm‑long screws securing the left joystick cover.
Lift and remove the left grip from the joystick.
Use the point of a spudger to flip up the black lock tab on the left joystick's ZIF connector.
Use a Phillips screwdriver to remove the two 2.9 mm‑long screws securing the joystick module to the Portal.
Shift the joystick module so that the flex cable slides out of its socket.
Remove the left joystick.
