Zum Hauptinhalt wechseln
SteelSeries Nimbus+ Triggers Replacement
Was du brauchst
  1. SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: Schritt 1, Bild 1 von 2 SteelSeries Nimbus+ Triggers Replacement, Remove the phone mount: Schritt 1, Bild 2 von 2
    • Use your fingers to remove the phone mount by pulling it straight out of the controller.
    Frag FixBot
  2. SteelSeries Nimbus+ Triggers Replacement, Remove the sticker: Schritt 2, Bild 1 von 1
    • Use your fingers to remove the sticker located on the back cover of the Nimbus+.
    • If you have trouble removing the sticker heat an iOpener and apply it to the rear case for two minutes to loosen the adhesive underneath.
    Frag FixBot
  3. SteelSeries Nimbus+ Triggers Replacement, Unscrew the back cover: Schritt 3, Bild 1 von 1
    • Use a Y1 Tri-point screwdriver to remove the five 9.1 mm-long screws securing the back cover.
    Frag FixBot
  4. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: Schritt 4, Bild 1 von 2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: Schritt 4, Bild 2 von 2
    • The back cover is held in place by plastic clips.
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the right controller handle.
    Frag FixBot
  5. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: Schritt 5, Bild 1 von 2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: Schritt 5, Bild 2 von 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the right edge.
    Frag FixBot
  6. SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: Schritt 6, Bild 1 von 2 SteelSeries Nimbus+ Triggers Replacement, Insert an opening pick: Schritt 6, Bild 2 von 2
    • Insert an opening pick into the gap between the front and back cover assembly at the outside of the left controller handle.
    Frag FixBot
  7. SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: Schritt 7, Bild 1 von 2 SteelSeries Nimbus+ Triggers Replacement, Release the plastic clips: Schritt 7, Bild 2 von 2
    • Slide the opening pick to the top of the controller to release the remaining plastic clips on the left edge.
    Frag FixBot
  8. SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: Schritt 8, Bild 1 von 3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: Schritt 8, Bild 2 von 3 SteelSeries Nimbus+ Triggers Replacement, Unfold the back cover assembly: Schritt 8, Bild 3 von 3
    • Carefully fold the back cover assembly to the top of the SteelSeries Nimbus+ and bring it in an 90 degree angle.
    • Do not try to remove the back cover assembly all the way yet! It is still connected to mainboard.
    Frag FixBot
  9. SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: Schritt 9, Bild 1 von 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: Schritt 9, Bild 2 von 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the battery cable: Schritt 9, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Use a pair of blunt nose tweezers to disconnect the battery cable from the mainboard.
    Frag FixBot
  10. SteelSeries Nimbus+ Triggers Replacement, Remove the back cover assembly: Schritt 10, Bild 1 von 1
    • Remove the back cover assembly.
    Frag FixBot
  11. SteelSeries Nimbus+ Triggers Replacement, Unscrew the board: Schritt 11, Bild 1 von 1
    • Use a Phillips screwdriver to remove the two 7.0 mm-long screws securing the board.
    Frag FixBot
  12. SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: Schritt 12, Bild 1 von 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: Schritt 12, Bild 2 von 3 SteelSeries Nimbus+ Triggers Replacement, Disconnect the thumbstick board: Schritt 12, Bild 3 von 3
    • Disconnect the thumbstick board by pulling it straight out its socket on the mainboard.
    Frag FixBot
  13. SteelSeries Nimbus+ Triggers Replacement, Remove the board: Schritt 13, Bild 1 von 1
    • Remove the board with the thumbsticks from the mainboard.
    Frag FixBot
  14. SteelSeries Nimbus+ Triggers Replacement, Unscrew the mainboard: Schritt 14, Bild 1 von 1
    • Use a Phillips screwdriver to remove the five 7.0 mm-long screws securing the mainboard to the front assembly.
    Frag FixBot
  15. SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: Schritt 15, Bild 1 von 3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: Schritt 15, Bild 2 von 3 SteelSeries Nimbus+ Triggers Replacement, Lift up the mainboard: Schritt 15, Bild 3 von 3
    • Use your fingers to lift up the mainboard from the front case.
    • Remove the mainboard.
    Frag FixBot
  16. SteelSeries Nimbus+ Triggers Replacement, Unscrew the triggers: Schritt 16, Bild 1 von 1
    • Use a Phillips screwdriver to remove the four 7.0 mm screws securing the triggers on the motherboard.
    Frag FixBot
  17. SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: Schritt 17, Bild 1 von 2 SteelSeries Nimbus+ Triggers Replacement, Release the right trigger: Schritt 17, Bild 2 von 2
    • Pull the right trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
    Frag FixBot
  18. SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: Schritt 18, Bild 1 von 2 SteelSeries Nimbus+ Triggers Replacement, Release the left trigger: Schritt 18, Bild 2 von 2
    • Pull the left trigger straight out to slide it off of the rails securing it to the button connector on the motherboard.
    Frag FixBot
Abschluss
Adriana Zwink
66.950 Reputation
167 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.805 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 34
Insgesamt: 599
