Zum Hauptinhalt wechseln
Lightweight fleece jackets maximize core warmth without weighting you down. They wick away moisture and dry quickly to handle the most grueling of outdoor pursuits.
How do you repair a rip in a fleece jacket?
My 10 year old son was playing outdoors in his fleece jacket today. The jacket has a front zipper and two pockets for one's hands. The jacket ripped / was torn by a large stick perhaps near the front hand pocket area. How does one fix this? Glue a patch? Iron-on a patch? Sew it? Send it back to Patagonia?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
1 Kommentar
OK, now I understand that it is glued. Can you tell me what kind of glue to use?
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hey Christina,
Any or all of those, except glue, could be answers depending on the hole. If it is small enough you can iron on a patch. If it is a larger tear you can satin stitch the hole. Do not glue on a patch as it will wash and wear funny, causing more wear on the jacket. You can check out our patching guides listed below for inspiration. Any of these methods should work for a tear in fleece.
Einen Riss in einem Hemd mit einer Flachstichnaht flicken
Aufnähflicken
Negativ-Flickenapplikation
Patagonia Sweater Professor Patch Replacement
Zickzack-Flicken
Einen Bügelflicken anbringen
Good luck and let us know how it goes!
Patagonia Jeans Bild
Anleitung
Zickzack-Flicken
Schwierigkeitsgrad:
Leicht
10 - 15 minutes
Anleitung
Schwierigkeitsgrad:
Leicht
15 - 20 minutes
Jeans Bild
Anleitung
Aufnähflicken
Schwierigkeitsgrad:
Leicht
10 minutes
Patagonia Shirt Bild
Anleitung
Schwierigkeitsgrad:
Leicht
10 - 15 minutes
Jeans Bild
Anleitung
Schwierigkeitsgrad:
Leicht
5 - 10 minutes
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
christina wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 23
Insgesamt: 21,945
