Zum Hauptinhalt wechseln
Das iPhone 6 mit dem 4,7 Zoll Display ist die kleinere Version des iPhone 6 Plus und kam am 19. September 2014 auf dem Markt. Es hat die Modelnnummern A1549, A1586 und A1589.
4994 Fragen Alle anzeigen
iPhone 6 screw is magnetic ITSELF, where does it go?
I have the earpiece bracket and the front panel assembly bracket(the one that covers the LCD/digitizer cable connections) removed, for a total of 8 screws I'm sitting here looking at.
The front panel assembly cable bracket takes three 1.2 MM screws along the bottom, a 3.1mm screw on the top right, and a 1.7 mm screw on the top left.
The earpiece bracket has one 2.3 mm screw on the top left, one 3 mm screw on the top right, and a 2.2 mm screw on the bottom right.
My problem is I'm scared if I mix up the 3.1mm and 3.0mm screw Ill fry something. Ive tried googling it but all I found was long screw damage, mostly talking about the 5. It said this wasn't as big of a problem for the 6?
Anyway, I can actually 100% tell one of the screws is longer. So that SHOULD be the one that goes top right in the front panel assembly cable bracket. However, while measuring I discovered it(the longer one) was very slightly magnetic itself.
Not as in it was attracted to a magnetic screwdriver - they all are.
As in it will stick to other screws and my nonmagnetic tweezers.
Having always been taught that the top right screw was nonmagnetic as a rule, this has me concerned. However I'm also thinking that the magnetic screw being right beside the earpiece speaker would interfere with it, so the magnetic screw probably goes in the top right of the display assembly cable bracket.
But I'm not sure. So really I'm asking where does the magnetic screw go?
And how much can I screw up the 6 if I were to put a screw in the wrong spot?
I have a feeling if the screw is magnetic it needs to be placed in the correct spot or it will fry something.
I've already tried using the guide, and its not really helping me.
Maybe I have to go buy a set of calipers?
Thank you for any help!
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Check this guide and go to Step 13, :)
iPhone 6 LCD mit Touchscreen tauschen
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
The guide isn't really giving me all I need here :(
I just figured out all of the screws are magnetized.
Do you have a close up picture of the earpiece bracket and front display assembly bracket(closer than the ones on the guide)?
I've got the screws lined up and have figured out their sizes with a ruler and process of elimination, but theres an extra screw actually and Im not sure where it came from. I dont even know which one is extra.
Ive figured out which are the 1.2's, which is the 3.0 and 3.1, which is the 2.2 and 2.3.
Now Im looking at two screws and cant figure out which is the 1.7 for the top left of the display assembly bracket.
The 2.3 has a bigger head than the 3's and the 2.2.
One of the ones I think is the 1.7 has this bigger head also.
von
We supply the screw measurements in every guide specifically as a failsafe in case you mix up your screws. So, I'd suggest following the guide and putting each screw exactly where it says, based on the length. I've repaired a number of iPhone 6 devices using that guide, and haven't had any problems.
That said, the best way to go is always to keep your screws clearly separated and labeled as you take them out, so there's never a question about where they go. I use a magnetic project mat for this; IMO it's one of the best and most indispensable tools we offer.
Best of luck finishing your repair!
Magnetic Project Mat Bild
Produkt
$19.95
Bewertung 1
Antwort hinzufügen
mbpiner wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 668
