Zum Hauptinhalt wechseln
Der DualShock 4 CUH-ZCT2 wurde 2016 angekündigt, um den 2013 veröffentlichten Controller CUH-ZCT1 zu ersetzen. Dieser Controller ähnelt dem Vorgängermodell.
L2 trigger wrong input
Hello, I have the following problem.
When I press the L2 button, the analog is apparently triggered up.
If I move the left analogue and press L2 again, the problem disappears, but on some drives it returns.
What could be the problem? What do they suggest?
Here's a video of the problem: https://youtu.be/u6hUOQScQnw
Thank you.
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
1 Antwort
I got a controller that was doing that issue and I found a permanent fix to this problem. If resetting the controller does not work, the problem is related to the joystick (joystick drift). Sometimes it will just need a clean to the potentiometer and other times, you will need to change it but they are very cheap and easy to change (no soldering require). I found this video that should help you to fix your issue : https://youtu.be/RcIza5Zz8qY
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Henrique Sameshima wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 855
