Zum Hauptinhalt wechseln
Offiziell lizenzierte Joy-Con-Alternative für die Nintendo Switch. Erschien im September 2019, gekennzeichnet durch die Modellnummern NSW-182 und NSW-182U.
Random drift on left controller
On my left hand controller it is just steering left and it was so random in just started happening if there is a way to reset it or something that would be nice thank you.
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
3 Antworten
If the analog sticks are not responding correctly, Hori recommends the following solution in the manual for the Split Pad Pro Attachment Set:
The Split Pad Pro Attachment Set is not compatible with the Nintendo Switch calibration menu.
In the case that the accessory's dedicated recalibration option does not work, it's possible that you have control stick drift. The solution in that case is the cleaning of the potentiometers or a replacement of the control stick module. A reference for disassembly is provided here.
I hope that your problem is solved in a quick and simple manner.
War diese Antwort hilfreich?
Bewertung 0
2 Kommentare:
This doesn’t tell you how to actually get to the potentiometer
von
If by potentiometer you are referring to the joystick, then sure it does. See the big red nob in the pictures. This joystick can be unsoldered from the board and replaced with one compatible with a Xbox. You aren't going to disassemble the joystick to get to the internal potentiometer.
von
Drift is a common problem with all joysticks. The best way to solve that problem with with a joystick replacement. The Hori Split Pro appears to be compatible with Xbox joystick replacements like can be found anywhere you search for "xbox joystick replacement". For example: https://a.co/d/5AmYLY1
Bewertung 0
necesito encontra el repuesto del joystick de ambos controles ya que el drift es horrible, saben donde encontrar el repuesto
Bewertung -1
1 Kommentar:
Seguramente cualquier reemplazo de joystick de Xbox funcionará. La distribución de pines es exactamente la misma. Por ejemplo: https://a.co/d/5AmYLY1
von
Antwort hinzufügen
Issac wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 53
Insgesamt: 4,815
