Upgraded to SSD, Mac starts but no boot ... No display, no keyboard
Hello I did'nt find better suggestion searching here. Here is the issue I've got with the late 2014 mac mini I've purchased second hand.
- It was working when i bought it ( 2,5 ghz processor, 8go Ram, Apple keyboard)
- carefully switched the internal 1To HDD with a samsung Evo SSD ( 500 gb)
- Did start the mac and heard the POST " chime" sound once. Did shut down ( I had no screen nor keyboard connected).
- After that , on next startup the "chime" POST sound never came back. I assumedthere was connection fault so I've checked everything and teardown/ remount several times since...
- connected it to a display with hdmi or mini display to vga ( both working with another mac) : no display whatsoever
- The power LED is working, no blinking
- The MAc mini heats but the Fan doesn't start
- caps lock of the USB apple keyboard doesn't work
- USB wired mouse does get power from usb and blnks
- external HDD mounted on a SATA / Usb 3 adaptor does get power and blinks
- no way to reinstall mac Os or to boot on the recovery , as I get no display and no keyboard access.
- did tryed to clone my MBP SSD to the internal SSD ( one more disassembly / assembly) , but no result.
- and now I just can't put the WI fi antenna back , maybe I've pinched the small connectors.. but I can live without WIFI :)
So I've heard about bootloader damaged or something like this, that could be helped with another mac and target disk mode start the Mac mini... That could work using a generic wired keyboard rather than the Apple USB wired keyboard, but it sounds weird.
* Does somebody know how I could fix that mess , or did i have bricked this cheap mac mini ? Is there another way to restore the system ?
- by the way thanks your for your helps and toolkit and advices.
Ist dies eine gute Frage?
