The Disc could not be read.
Red Error Message: The Disc could not be read. Please read the Nintendo Gamecube instruction book for more information.
Ist dies eine gute Frage?
@johnllovesr try and see if it reads an audio disk as well as different game disk then the one you were trying. Sometimes a disk can cause this error.
It is possible that this is either a dirty laser or a failing laser. First try one of those commercially available CD cleaner kits. Run that a couple of times. If that does not work you could could try to increase the power to your laser. Follow this guide. Just be moderate, you do not want to burn it out. The other thing to try would be a recalibration of the lens. For that follow this guide. After that I'd suggest that you replace either the lens or the optical drive. Nintendo GameCube Laseroptik tauschen Nintendo GameCube optische Laufwerkbaugruppe tauschen
Anleitung
Schwierigkeitsgrad:
Mittel
30 - 45 minutes
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes
Anleitung
Schwierigkeitsgrad:
Mittel
30 minutes
Anleitung
Schwierigkeitsgrad:
Mittel
20 - 25 minutes
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 19
