Hi,
I'm also facing kinda similar situation.
After upgrading to 1.0.7, the station displayed messages about battery error and said something like it stopped charging. Battery level jumped from ~80% to 100%. From that point, it was impossible to plug anything into the front USB port, nothing connected / charged. The station was properly starting the application but was stuck in some issues regarding the battery.
I contacted support which indicated me this ongoing issue.
Since anyway everything was stuck, I tried to downgrade to 1.0.6 but unfortunately the device wasn't connecting anymore to the PC (so it was not really in a good shape). I hence went with the procedure to go into DFU mode. The device connected again and I performed the 1.0.6 downgrade. Now I'm experiencing the same issue than @blakethoennes : the firmware updates, the device resets and an error message is displayed saying the update didn't went well. And from this point, the device is stuck with a black screen, not connecting anymore, ... Going into DFU mode and trying a new upgrade is possible but it does not help at all, same things happens again.
Before returning the device for a replacement, I'm eager to wait for a 1.0.8 fw or new set of instructions to follow to un-brick. I feel like it would bring more value than simply replacing the device. @brett do you have any new estimate regarding when this might happen. I totally understand this is probably not an easy thing and can take more time than anticipated, but I would appreciate to be kept informed on the progress made.
Should it be impossible, would it be possible for the support to simply send a new motherboard and I will do the switch? As a repair fan, it would make much more sense than sending a heavy station with it's heavy battery and case back to the factory.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
2
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
13 Kommentare
Mines brand new with no life out of the box. no display. Went through included instructions assuming it was a dead battery left it to charge... no indications that its charging.
looks like we have a batch of defectives to get replaced?
von Blake Thoennes
@blakethoennes , This is not the experience we want you to have. Have you reached out to support@ifixit.com yet?
von Kris Rodriguez
I have reached out to support. I have not had a response back, but it has been less than 24 hours. Other posters with similar issue have received replacement devices. I am confident, in time, Ifixit will solve all my issues without worry. I remain patient for my support response. Since then, I have performed a number of other suggested repair options...
holding blue power button for 10 seconds, disconnecting battery from inside for 10 minutes, holding silver wheel in during connection for web dfu connection (failed to load page), and can confirm a two red lights on the inside pcb, and after dfu shows as connectable in webview (though fails to load page), of the two , one goes out, leaving the remaining solid red led.
von Blake Thoennes
@krisrodriguez , I have sent an email to support@ifixit.com regarding this.
von James P
This just happened to mine. Same exact process. I noticed a D4 led on the pcb inside blinks rapidly when the iron is plugged in. The screen doesn't do anything, just stays blank. Holding the silver button and plugging it into the laptop made it to where the web interface will detect the Hub, but everything is still unresponsive. the D6 Led is currently lit up solid on the pcb when just plugged into the laptop with no soldering iron plugged in.
von Tristan Scott
8 weitere Kommentare anzeigen
