Zum Hauptinhalt wechseln
Dell Precision 5520 Battery Replacement
Was du brauchst
  1. Dell Precision 5520 Battery Replacement, Base Cover: Schritt 1, Bild 1 von 2 Dell Precision 5520 Battery Replacement, Base Cover: Schritt 1, Bild 2 von 2
    • Be sure to power off and unplug your device before you begin your repair.
    • Turn the system badge flap over (1) and then remove the ten M2x3 screws that secure the base cover to the computer (2).
    • Pry the edges of the base cover and lift it to remove it from the computer.
    • NOTE: Use a Torx #5 screwdriver for the base screws and a Phillips screwdriver for the two M2x8 screws inside the badge flap.
    Frag FixBot
    Kommentar hinzufügen
  2. Dell Precision 5520 Battery Replacement, Battery: Schritt 2, Bild 1 von 1
    • Disconnect the battery cable from the system board [1].
    • Remove the seven M2x4 screws that secure the battery to the computer [2].
    • Lift the battery off the computer [3].
    • Do not apply pressure to the surface of the battery
    • Do not bend
    • Do not use tools of any kind to pry on or against the battery
    • If a battery cannot be removed within the constraints above, please contact Dell technical support
    Frag FixBot
Abschluss
14 weitere Personen haben diese Anleitung absolviert.
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
45 Mitglieder
2.003 Anleitungen geschrieben
2 Kommentare zur Anleitung
Great directions. Simple, yet precise. Took less than five minutes.
Sam Kamara - Antwort Teilen
Easy peasy. Great instruction, exact parts with exact tools. Great price. Thanks IFIXIT!
Jason W Wines - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 33
Letzte 30 Tage: 146
Insgesamt: 15,873
