Zum Hauptinhalt wechseln
Google Pixel Watch 4 Battery Replacement
Was du brauchst
  1. Google Pixel Watch 4 Battery Replacement, Prepare your watch for disassembly: Schritt 1, Bild 1 von 3 Google Pixel Watch 4 Battery Replacement, Prepare your watch for disassembly: Schritt 1, Bild 2 von 3 Google Pixel Watch 4 Battery Replacement, Prepare your watch for disassembly: Schritt 1, Bild 3 von 3
    • Before starting your repair:
    • Remove your watch from the charger.
    • Press and hold the crown button, then tap Power off to shut down your watch.
    Frag FixBot
    Kommentar hinzufügen
  2. Google Pixel Watch 4 Battery Replacement, Remove the watch bands: Schritt 2, Bild 1 von 3 Google Pixel Watch 4 Battery Replacement, Remove the watch bands: Schritt 2, Bild 2 von 3 Google Pixel Watch 4 Battery Replacement, Remove the watch bands: Schritt 2, Bild 3 von 3
    • Remove each watch band by depressing the release button and sliding the band out of its groove.
    Frag FixBot
  3. Google Pixel Watch 4 Battery Replacement: Schritt 3, Bild 1 von 1
    • Throughout the rest of your repair, consider placing your watch on something soft like a clean cloth to help stabilize it and prevent scratches to the front glass.
    Frag FixBot
  4. Google Pixel Watch 4 Battery Replacement, Remove the back sensor glass screws: Schritt 4, Bild 1 von 3 Google Pixel Watch 4 Battery Replacement, Remove the back sensor glass screws: Schritt 4, Bild 2 von 3 Google Pixel Watch 4 Battery Replacement, Remove the back sensor glass screws: Schritt 4, Bild 3 von 3
    • Use a Torx Plus 2IP screwdriver to remove the 3.0 mm‑long screw from both watch band grooves (two screws total).
    • Both screws have a tiny O‑ring. If they don't lift away with the screw, use a pair of tweezers to carefully remove them from the band groove and set them aside. These O-rings are required to maintain waterproofing.
    • Handle these O-rings carefully. Avoid pinching or slicing them with your tool.
    • During reassembly:
    • Make sure the O‑rings are on the screws before installing them.
    • Push down firmly on the back glass while installing the screws to make sure the glass gets properly seated.
    • If there's a gap between the back glass and frame, remove the screws and reinstall them.
    Frag FixBot
  5. Google Pixel Watch 4 Battery Replacement, Separate the back sensor glass: Schritt 5, Bild 1 von 2 Google Pixel Watch 4 Battery Replacement, Separate the back sensor glass: Schritt 5, Bild 2 von 2
    • Insert the point of a spudger (or a clean fingernail) into the seam between the back sensor glass and frame and pry up until the cover detaches.
    Frag FixBot
  6. Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: Schritt 6, Bild 1 von 3 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: Schritt 6, Bild 2 von 3 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: Schritt 6, Bild 3 von 3
    • Gently lift the back glass and flip it over the side of the watch opposite the crown.
    • Be careful not to strain the cable connecting the back sensor glass.
    Frag FixBot
  7. Google Pixel Watch 4 Battery Replacement, Remove the vibration motor screws: Schritt 7, Bild 1 von 2 Google Pixel Watch 4 Battery Replacement, Remove the vibration motor screws: Schritt 7, Bild 2 von 2
    • Optionally, you can disconnect the back glass to give you more room to work—though you can complete the repair just fine with it still connected.
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the vibration motor.
    Frag FixBot
  8. Google Pixel Watch 4 Battery Replacement, Remove the vibration motor: Schritt 8, Bild 1 von 2 Google Pixel Watch 4 Battery Replacement, Remove the vibration motor: Schritt 8, Bild 2 von 2
    Frag FixBot
  9. Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: Schritt 9, Bild 1 von 3 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: Schritt 9, Bild 2 von 3 Google Pixel Watch 4 Battery Replacement, Reposition the back sensor glass: Schritt 9, Bild 3 von 3
    • Gently flip the back sensor glass over the crown-side of the watch.
    Frag FixBot
  10. Google Pixel Watch 4 Battery Replacement, Disconnect the battery: Schritt 10, Bild 1 von 2 Google Pixel Watch 4 Battery Replacement, Disconnect the battery: Schritt 10, Bild 2 von 2
    • Use the point of a spudger to pry up and disconnect the battery press connector.
    • During reassembly, use the point of a spudger to press down and reconnect the press connector.
    • This can be tricky, and may take a few tries.
    • If you're having trouble, loosen the two battery screws and reposition the connector. Once connected, re-tighten the battery screws.
    Frag FixBot
  11. Google Pixel Watch 4 Battery Replacement, Remove the battery screws: Schritt 11, Bild 1 von 2 Google Pixel Watch 4 Battery Replacement, Remove the battery screws: Schritt 11, Bild 2 von 2
    • Use a Torx Plus 2IP screwdriver to remove the two 2.2 mm‑long screws securing the battery.
    Frag FixBot
  12. Google Pixel Watch 4 Battery Replacement, Remove the battery: Schritt 12, Bild 1 von 3 Google Pixel Watch 4 Battery Replacement, Remove the battery: Schritt 12, Bild 2 von 3 Google Pixel Watch 4 Battery Replacement, Remove the battery: Schritt 12, Bild 3 von 3
    • Remove the battery.
    Frag FixBot
Abschluss
For optimal performance, calibrate your newly installed battery after completing this guide.
Eine weitere Person hat diese Anleitung absolviert.
Spencer Day
191.315 Reputation
1.204 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 16
Letzte 7 Tage: 76
Letzte 30 Tage: 547
Insgesamt: 4,309
