Zum Hauptinhalt wechseln
HP 15-dy Battery Replacement
Was du brauchst
  1. HP 15-dy Battery Replacement, Prepare your laptop for disassembly: Schritt 1, Bild 1 von 1
    • Fully shut down your laptop and unplug all cables.
    Frag FixBot
    Kommentar hinzufügen
  2. HP 15-dy Battery Replacement, Flip your laptop over: Schritt 2, Bild 1 von 1
    • Flip your laptop over so the rubber feet are facing up.
    Frag FixBot
  3. HP 15-dy Battery Replacement, Peel up an end of the front foot: Schritt 3, Bild 1 von 3 HP 15-dy Battery Replacement, Peel up an end of the front foot: Schritt 3, Bild 2 von 3 HP 15-dy Battery Replacement, Peel up an end of the front foot: Schritt 3, Bild 3 von 3
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
    Frag FixBot
  4. HP 15-dy Battery Replacement, Remove the front foot: Schritt 4, Bild 1 von 3 HP 15-dy Battery Replacement, Remove the front foot: Schritt 4, Bild 2 von 3 HP 15-dy Battery Replacement, Remove the front foot: Schritt 4, Bild 3 von 3
    • Peel the front foot away from the back cover and remove it.
    Frag FixBot
  5. HP 15-dy Battery Replacement, Remove the rear foot: Schritt 5, Bild 1 von 3 HP 15-dy Battery Replacement, Remove the rear foot: Schritt 5, Bild 2 von 3 HP 15-dy Battery Replacement, Remove the rear foot: Schritt 5, Bild 3 von 3
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
    Frag FixBot
  6. HP 15-dy Battery Replacement, Reassembly information: Schritt 6, Bild 1 von 3 HP 15-dy Battery Replacement, Reassembly information: Schritt 6, Bild 2 von 3 HP 15-dy Battery Replacement, Reassembly information: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Tesa 61395 Tape
    $8.95
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
    Frag FixBot
  7. HP 15-dy Battery Replacement, Unfasten the back cover: Schritt 7, Bild 1 von 2 HP 15-dy Battery Replacement, Unfasten the back cover: Schritt 7, Bild 2 von 2
    • Use a Phillips screwdriver to remove the eight screws securing the back cover:
    • Six 6.5 mm-long silver screws
    • Two 6.7 mm-long black screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
    Frag FixBot
  8. HP 15-dy Battery Replacement, Open your laptop: Schritt 8, Bild 1 von 3 HP 15-dy Battery Replacement, Open your laptop: Schritt 8, Bild 2 von 3 HP 15-dy Battery Replacement, Open your laptop: Schritt 8, Bild 3 von 3
    • Flip your laptop over and open the screen.
    Frag FixBot
  9. HP 15-dy Battery Replacement, Release the clips: Schritt 9, Bild 1 von 2 HP 15-dy Battery Replacement, Release the clips: Schritt 9, Bild 2 von 2
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
    • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
    Frag FixBot
  10. HP 15-dy Battery Replacement: Schritt 10, Bild 1 von 2 HP 15-dy Battery Replacement: Schritt 10, Bild 2 von 2
    • Avoid using excessive force when prying near the SD card slot, as it's a weak point in the case.
    • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
    • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
    Frag FixBot
  11. HP 15-dy Battery Replacement: Schritt 11, Bild 1 von 3 HP 15-dy Battery Replacement: Schritt 11, Bild 2 von 3 HP 15-dy Battery Replacement: Schritt 11, Bild 3 von 3
    • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
    • Slide the opening pick to the bottom left corner to release the remaining clips.
    Frag FixBot
  12. HP 15-dy Battery Replacement, Flip your laptop over: Schritt 12, Bild 1 von 3 HP 15-dy Battery Replacement, Flip your laptop over: Schritt 12, Bild 2 von 3 HP 15-dy Battery Replacement, Flip your laptop over: Schritt 12, Bild 3 von 3
    • Close the screen and flip your laptop back over again.
    Frag FixBot
  13. HP 15-dy Battery Replacement, Remove the back cover: Schritt 13, Bild 1 von 3 HP 15-dy Battery Replacement, Remove the back cover: Schritt 13, Bild 2 von 3 HP 15-dy Battery Replacement, Remove the back cover: Schritt 13, Bild 3 von 3
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
    Frag FixBot
  14. HP 15-dy Battery Replacement, Unfasten the battery: Schritt 14, Bild 1 von 2 HP 15-dy Battery Replacement, Unfasten the battery: Schritt 14, Bild 2 von 2
    • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
    Frag FixBot
  15. HP 15-dy Battery Replacement, Remove the battery: Schritt 15, Bild 1 von 3 HP 15-dy Battery Replacement, Remove the battery: Schritt 15, Bild 2 von 3 HP 15-dy Battery Replacement, Remove the battery: Schritt 15, Bild 3 von 3
    • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
    • Remove the battery.
    • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
    Frag FixBot
Abschluss
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
12 weitere Personen haben diese Anleitung absolviert.
Spencer Day
191.306 Reputation
1.204 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
122 Mitglieder
25.947 Anleitungen geschrieben
6 Kommentare zur Anleitung
The guide is fine, with one exception. It appears that the instructions for the rubber strips on the bottom are backwards. The deeper groove for the rubber strip is, in fact, in the back, not the front as stated. The shallower groove is in the front of the computer, not the back.
Kevin “Caoimhín” Cotham - Antwort Teilen
Thank you for the comment, the guide has been updated!
Spencer Day - Antwort Teilen
Thank you for the well written guide on replacing the battery on my almost 4 year old HP 15-EF laptop. The steps along with the pics. made it fairly simple and quick.
Cheers!
Ray L.
Horace the Horror - Antwort Teilen
Very nice guide, thank you!! I splurged and bought the genuine HP replacement battery from iFixit. It's like triple the price of a knock off Chinese battery but I think it is worth it overall. Those knockoff batteries rarely perform well. I also purchased the Tesa 61395 4mm tape to reattach the rubber feet properly. 5mm would have been better but they only had 4mm or 6mm and not sure if 6mm would fit. Using this guide the fix went really smoothly with an HP 15-dy1038n purchased in December 2019.
14vs35 - Antwort Teilen
Do you recommend any particular site(s) for purchasing the battery?
eriq73 - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 110
Letzte 30 Tage: 454
Insgesamt: 13,524
