Zum Hauptinhalt wechseln
Canon EOS 60D Rubber grips Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
Canon EOS 60D Rubber grips Replacement: Schritt 0, Bild 1 von 1
  • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
  • Repeat for the other two grips
  • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
  • The small one on the back is a bit difficult to get started, but not really difficult to remove.
  • The one on the AV panel will be easier if you open up the AV port cover.
  • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
  • Optionally throw the balled up adhesive at people pretending its a booger :)
Hier Übersetzung einfügen
