Zum Hauptinhalt wechseln
Xbox One Disc Drive PCB Replacement
Englisch
Koreanisch
Schritt 4
Xbox One Disc Drive PCB Replacement, Desolder the cables: Schritt 0, Bild 1 von 3 Xbox One Disc Drive PCB Replacement, Desolder the cables: Schritt 0, Bild 2 von 3 Xbox One Disc Drive PCB Replacement, Desolder the cables: Schritt 0, Bild 3 von 3
Desolder the cables
  • You will see an red and an black cable soldered to the PCB.
  • Now get your solder iron ready to desolder the 2 cables. Heat and melt the solder, with your other hand hold the tweezer. When the solder is melting, remove the cable with your tweezer to get the cable out.
  • It's recommended you use desoldering wick, so you can put some fresh new solder on the pads. Recommended but not required.
  • Now it should look like the last photo.
Hier Übersetzung einfügen
