Schritt 3 übersetzen
Schritt 3
Flip the TV over, LCD side up.
Carefully remove the plastic bezel, gently bending the tabs that hold it the frame.
Remove the LCD panel. Caution!' The LCD panel is fragile and breaks easily. Slide a large cardboard sheet under the display and carefully support the panel's weight without any bending. (If it cracks, well, you now have a much more expensive repair problem.)
Be sure you have a stable surface large enough to hold the LCD panel.
