Zum Hauptinhalt wechseln
Xbox Series S 플라스틱 케이스 교체하기
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 8 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: Schritt 0, Bild 1 von 3 Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: Schritt 0, Bild 2 von 3 Xbox Series S Plastic Case Replacement, Peel off the sticker coverings: Schritt 0, Bild 3 von 3
  • Before you start this guide, turn off the Xbox and unplug any cables from it.
  • Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
이 안내서를 시작하기 전에 Xbox를 끄고 모든 케이블을 분리하세요.
핀셋을 사용해 후면 패널 하단 모서리에 있는 흰색 나사 커버 두 개를 벗겨주세요.
[title] Peel off the sticker coverings
[* icon_caution] Before you start this guide, turn off the Xbox and unplug any cables from it.
-[* black] Use tweezers to peel off the two white screw covers located on the bottom corners of the back panel.
+[* black] Use [product|IF145-020|tweezers] to peel off the two white screw covers located on the bottom corners of the back panel.
