Zum Hauptinhalt wechseln
Microsoft Surface Pro 6 Opening Procedure
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 13 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 19
Microsoft Surface Pro 6 Opening Procedure: Schritt 0, Bild 1 von 2 Microsoft Surface Pro 6 Opening Procedure: Schritt 0, Bild 2 von 2
  • Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
  • Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
  • Repeat this procedure at different points around the shield until it is free. Remove the shield.
  • Try not to deform the shield too much—you will need to reinstall it during reassembly.
핀셋의 한 뾰족한 부분을 디지타이저 커넥터를 덮고 있는 EMI 실드 가장자리의 틈에 끼우세요.
핀셋을 사용하여 디스플레이를 구부리지 않으며 디스플에이에서 최대한 멀찍이 EMI 실드를 들어 올리세요.
실드가 자유롭게 분리될 때까지 실드 주변의 다른 부분에도 이 절차를 반복하세요. 실드를 분리하세요.
실드를 너무 많이 변형하지 마세요—재조립할 때 실드를 다시 설치해야 합니다.
-[* black] Insert one point of a pair of pointed tweezers into a gap in the edge of the EMI shield covering the digitizer connector.
+[* black] Insert one point of a pair of [product|IF145-020-2|pointed tweezers] into a gap in the edge of the EMI shield covering the digitizer connector.
[* black] Use the tweezers to pry the EMI shield away from the display as much as you can without bending it.
[* black] Repeat this procedure at different points around the shield until it is free. Remove the shield.
[* icon_caution] Try not to deform the shield too much—you will need to reinstall it during reassembly.
