Zum Hauptinhalt wechseln
Cricut Maker 3 Belt Replacement
Englisch
Koreanisch
Schritt 15
Cricut Maker 3 Belt Replacement: Schritt 0, Bild 1 von 1
  • The screws in this step have different threads. Keep close track of where the screws go to avoid stripping the screw wells.
  • Use a Phillips screwdriver to remove eight screws from the right side of the Cricut:
  • Two 10.2 mm‑long screws securing the right end top metal track, which include a washer and a locking washer.
  • Four 10.0 mm‑long screws securing the large white plastic bracket.
  • Two 7.9 mm‑long screws securing the large white plastic bracket, which include white plastic spacers.
  • During reassembly:
  • Check that the tool holder slides freely with the top metal track fully seated before re-installing any screws. If it doesn't, you may need to tilt the top of the tool holder forwards slightly so it's completely in the top track.
  • Reconnect the motor ground wire to the right-most screw that secures the right end of the top metal track.
Hier Übersetzung einfügen
