Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 2 Anleitungen, die diese grundständige Anleitung beinhalten.
Schritt 1 übersetzen
Using the plastic remover tool carefully unseat the four rectangular electric leads from the board. Each rectangle is a different size, the first one is large, the second one is medium, and the last two are small.
Using the plastic remover tool carefully unseat the square electric lead (marked in orange) from the board.
Using the plastic remover tool carefully unseat the small square and the two rectangular electric leads (marked in yellow) from the board.
[title] Disconnect All Relays | |
- | [* black] Using a plastic remover tool, carefully unseat each of the electric leads plugged into the board. |
+ | [* red] Using the plastic remover tool carefully unseat the four rectangular electric leads from the board. Each rectangle is a different size, the first one is large, the second one is medium, and the last two are small. |
+ | [* orange] Using the plastic remover tool carefully unseat the square electric lead (marked in orange) from the board. |
+ | [* yellow] Using the plastic remover tool carefully unseat the small square and the two rectangular electric leads (marked in yellow) from the board. |
