Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 19 Anleitungen, die diese beinhalten.
Schritt 1 übersetzen
Schritt 1
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
[* red] Two screws are hidden underneath two rubber feet highlighted in red. | |
[* black] Use the tip of a spudger to pry the rubber feet out of the lower case. | |
+ | [* icon_note] Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber. |
