Zum Hauptinhalt wechseln
DigiLand DL701Q Back Case Replacement
Hinweis: Du bearbeitest eine grundständige Anleitung. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese beinhalten.
Englisch
Koreanisch
Schritt 1 übersetzen
Schritt 1
DigiLand DL701Q Back Case Replacement: Schritt 0, Bild 1 von 3 DigiLand DL701Q Back Case Replacement: Schritt 0, Bild 2 von 3 DigiLand DL701Q Back Case Replacement: Schritt 0, Bild 3 von 3
  • Make sure your device is turned off.
  • Hold the device firmly, in landscape view.
  • Locate the crevice that separates the front cover from the back cover. Then hold the plastic opening tool and insert the wedge portion of the tool into the crevice.
  • Some force may need to be applied and there may be a cracking sound. This is normal.
  • Slowly slide the wedge portion of the plastic opening tool while applying some upward force around the device until the back cover is completely loose.
  • Only apply enough force to loosen the back cover. Excessive force may damage the screen.
Hier Übersetzung einfügen
