Zum Hauptinhalt wechseln
1990-1997 Mazda Miata Oil Change
Englisch
Koreanisch
Schritt 13
1990-1997 Mazda Miata Oil Change: Schritt 0, Bild 1 von 2 1990-1997 Mazda Miata Oil Change: Schritt 0, Bild 2 von 2
  • When the draining oil slows to a drip, wipe off the area around the drain plug and reinstall it by first tightening it by hand.
  • Finish tightening the drain plug with a 19 mm box end wrench or socket wrench.
  • Only tighten the drain plug until it is snug. Over-tightening the oil drain plug can strip or crack the oil pan—a very costly error. You can always tighten the drain plug more later.
  • If using a torque wrench to tighten the drain plug, set the torque to : 29-41 N-m; 22-30 ft-lbs
  • Wipe off the area around the drain plug one more time with a rag or towel.
Hier Übersetzung einfügen
