Zum Hauptinhalt wechseln
MacBook Pro 17" Unibody Front Display Glass Replacement
Hinweis: Du bearbeitest gerade eine grundständige Anleitung, die Teil der Anleitung ist, die du eben angeschaut hast. Alle Änderungen, die du vornimmst, betreffen alle 5 Anleitungen, die diese grundständige Anleitung beinhalten.
Englisch
Deutsch
Schritt 5
MacBook Pro 17" Unibody Front Display Glass Replacement: Schritt 0, Bild 1 von 1
  • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the display.
  • Before starting, be sure to clean the display glass with a lint-free cloth moistened with a mild solution; it will make the suction cup adhere better, and will make checking for dust on reassembly easier.
  • With the heat gun set to low, start by heating the outer black border near the upper right corner of the glass panel.
  • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
Hier Übersetzung einfügen
