Zum Hauptinhalt wechseln
1991-1996 Chevrolet Caprice Battery Replacement
Vaughn Higginbotham
Vaughn Higginbotham und 3 weitere Mitwirkende
Zuletzt aktualisiert am July 6, 2017
30 Minuten
Mittel
Anleitung eines Community-Mitglieds
  1. 1991-1996 Chevrolet Caprice Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Find the hood lever, this is normally under the dash, to the left of the steering wheel.
  2. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 2, Bild 1 von 1
    • Pull the lever and the hood will pop up.
  3. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 3, Bild 1 von 1
    • Go to the front of the car and push the lever up to unlatch the hood, you may need to feel around for a minute to find this.
  4. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 4, Bild 1 von 1
    • Find the battery, this is normally to the left front of the engine.
  5. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 5, Bild 1 von 1
    • Once you have found the battery. It is time to unscrew the bolts holding in the wires.
    • The red circle is positive and the black circle is the negative.
    • If you see battery acid on the terminal bolts remove this be using baking soda mixed with water and a tooth brush.
  6. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 6, Bild 1 von 1
    • With your 8mm wrench remove the negative terminal bolt.
    • Make sure the negative and positive terminals do not touch!
  7. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 7, Bild 1 von 1
    • Now with your 15mm wrench remove the positive terminal bolt, the same way you removed the negative terminal bolt.
  8. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 8, Bild 1 von 2 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 8, Bild 2 von 2
    • With your 13mm socket, remove the bolt that holds the block, that holds the battery in. This bolt will not come out completely. Once you feel slack in the bolt you may remove the whole block.
    • Make sure you do not touch the positive and negative terminals, you might get shocked!
  9. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 9, Bild 1 von 1
    • Now lift out the battery using the handle shown.
    • To recycle your old battery take it back to the store where you bought the new battery.
  10. 1991-1996 Chevrolet Caprice Battery Replacement: Schritt 10, Bild 1 von 1
    • To install the new battery follow these steps in reverse order from step 8-5.
    • When putting the battery bolts back in, make sure you put the negative bolt in first and then the positive bolt in second.
Abschluss
Also find the right battery for this type of car.
6 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 6,531
