Zum Hauptinhalt wechseln
2 - Toasters - How do they work?
Atelier Soudé
Atelier Soudé und eine weitere beteiligte Person
Zuletzt aktualisiert am September 8, 2024
Keine Schätzung
Leicht
Anleitung eines Community-Mitglieds
We are looking here at the various components that make up the toaster, understanding their purpose, how each of them works individually, and, also, how they interact with each other.
The following article should also be useful.
https://home.howstuffworks.com/toaster.h...
  1. 2 - Toasters - How do they work?, General working principle: Schritt 1, Bild 1 von 3 2 - Toasters - How do they work?, General working principle: Schritt 1, Bild 2 von 3 2 - Toasters - How do they work?, General working principle: Schritt 1, Bild 3 von 3
    • When lever 1 moves down, it lowers the basket containing the bread as well as a cam labelled 2. When this cam arrives at the end of the rail, it gets in position in between the two copper plates of the bipolar switch labelled 3.
    • These two copper plates are used to power on the toaster.
    • If the toaster is plugged in, the lever is held down by an electro-magnet 4. Time setting of the magnet is chosen using the button placed on top of the toaster actuating the electronic timer 5
    • To toast bread, the device has a network of heating elements 6 placed on both sides of the basket on insulating plates 7. The elements are powered when the lever is held down.
  2. 2 - Toasters - How do they work?, Electronic operating principle: Schritt 2, Bild 1 von 2 2 - Toasters - How do they work?, Electronic operating principle: Schritt 2, Bild 2 von 2
    • When the lever is lowered, the contact pads of the bipolar switch 3 are closed. This allows the network of heating elements6, the electronic card 5 and the electromagnet 4 to be turned on.
    • When the electromagnet is powered, it keeps the lever lowered. This process is controlled by the timer on the electronic card.
    • When the time is up or the "stop" button is pressed, the timer releases the electro-magnet, which lets the lever rise with the tension of the spring and brings up the basket with the toasts inside. The toaster's circuit is then off.
  3. 2 - Toasters - How do they work?, Electronic operating principle: Schritt 3, Bild 1 von 3 2 - Toasters - How do they work?, Electronic operating principle: Schritt 3, Bild 2 von 3 2 - Toasters - How do they work?, Electronic operating principle: Schritt 3, Bild 3 von 3
    • This is an example of an electronic diagram of a toaster timer. The manufacturers use various assemblies often based on a frequency oscillator and a timer (The MC14541BCP, datasheet provided here). The setting of the time is done with a potentiometer (P1 here).
    • Each device is slightly different, so we won't go into the detail of the electronics here.
    • The modified tip at the bottom of the diagram is worth noting. This prolongs the longevity of the contacts of the bipolar switch (see the chapter on the origin of toasters' breakdowns) Necessary tools: 1 triac BT138 + 1 resistance 4,7k
    • Source: http://www.rvq.fr/tech/g-pain.php
Abschluss
Now that we know what our appliance does, and we understand the sub-assemblies and how they work, we can proceed to the repair stage with the following tutorial: “Toaster: Common Breakdowns”
15 weitere Personen haben diese Anleitung absolviert.
fr en
100%
Hier starten ›
Atelier Soudé
3.691 Reputation
15 Anleitungen geschrieben
Atelier Soudé Mitglied von Atelier Soudé
Local Repair Groups
5 Mitglieder
30 Anleitungen geschrieben
2 Kommentare
bonjour
J’ai un grille pain un composant monté en surface a grillé.
Il semblerait que ce soit un triac mais comment savoir en particulier avec quoi il pourrait être remplacé ? Triac monté en surface ou non d’ailleurs.
Merci d’avance
Bon dimanche
P LP - Antwort
Bonjour,
Il semble en effet que le composant grillé soit un triac, ce qui est assez fréquent dans les appareils de ce type. Pour déterminer précisément avec quoi le remplacer, vous pourriez consulter un site spécialisé comme Mon Grille-Pain. Ce site propose une gamme de pièces détachées, ainsi que des guides pour identifier et remplacer les composants usés. Cela pourrait aussi être l’occasion d’envisager un nouvel appareil si le coût de la réparation est trop élevé par rapport à un modèle neuf.
Bon courage pour la réparation, et bon dimanche !
Cordialement,
Tallo16 -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 90
Letzte 30 Tage: 338
Insgesamt: 13,547
